COMPLETED Airfix 1/72 Fw 190 A-8...from Catalonia
  • stona
    • Jul 2008
    • 9889
    Here it is. I wanted a closed canopy, but I know when I'm beaten and have posed it open. I will add the retractable step which is being painted.
    I wanted a bit of fun with this, hence the bloke trying to move the sheep away. I have no idea why I have some sheep this size in my cupboard
    A bit about the unit with which this aircraft served.
    Jagdgruppe 10 (Jgr.10) was formed in July 1944 from Erprobungskommando 25, a specialist unit which tested experimental weapons and tactics to counter the USAAF’s heavy bombers. It comprised only three Staffeln. This aircraft is from 3./JGR.10 which kept its Fw 190 As until the end. The other two Staffeln (Stabstaffel and 2. Staffel) exchanged theirs for 'Doras' in late 1944.
    The unit experimented with all sorts of systems most of which were not successful. It would have been nice for Airfix to do one of those that did work after a fashion, there is a good picture of one of the units aircraft carrying the 21cm Wurfgranate (WGr.21) tubes for example.
    For one that didn’t work, there is a good picture of an aircraft fitted with the 21cm Krebs-Gerat rocket. This was a rocket with a 2 second fuse which was supposed to be fired rearwards from the Fw 190 as it passed the bomber formation after a head on attack.
    More successful were experiments with the R4M rocket system. The unit also tested the EZ 42 gyro gun sight.
    One of the more bizarre weapons tested was an upward firing cannon armament triggered electronically as the fighter passed under a bomber. This was tested over the Baltic using an He 177, from which the pilot had bailed out, as a target. The system failed and the He 177, having made a leisurely turn back towards land, had to be shot down using conventional armament.
  • Alan 45
    • Nov 2012
    • 9833
    I have watched this come together from the sidelines and I must say it makes a very good looking plane Steve ,
    Great build
    • Centurion3RTR
      • Jan 2009
      • 2093
      Cracking build there Steve mate, alway love your builds because we get some history with it.
      Have fun, John
        As I said, a fantastic build
        Can I ask if you has some problems finally with the legs, or just leave as comes from the kit? O_o
        I'm glad you like it Steve! Next time will be a 1/32, I promise :P
        Polux
        • stona
          • Jul 2008
          • 9889
          Originally posted by \
          As I said, a fantastic build Can I ask if you has some problems finally with the legs, or just leave as comes from the kit? o_O
          Polux
          I had a disaster with the kit U/C legs when trying to shorten them. I decided to take a couple of millimetres out of the oleo piston, which was fine, but I messed up the scissor links and they just didn't look okay.
          The undercarriage on the kit now is from another kit I had. I'm not sure what make it is. I shortened these legs by taking some length off from the top. The trick then is getting the angles correct.
          My rule of thumb for the fore/aft rake is that with the aircraft parallel to the ground the back of the tyre should line up with the leading edge of the wing.
          For the other angle (left/right) the inside edge of the tyre lines up roughly with where the actuator arm attaches to the electric motor on the spar.
          I've also got a decent drawing which I can refer to and make fine adjustments by eye!
          I'm eyeing up that Ju 88 now
          • john i am
            • Apr 2012
            • 4019
            Baaaaaaah! I don't believe the story about the sheep I reckon you went out especially to get them.(only joking lol) magnificent build though and great backdrop cheers John
              Great build mate
              • Wendall
                • Jun 2013
                • 918
                Fantastic job Steve
                  • 18266
                  That Steve is a very tidy Fw.
                  Interesting history as well. I can imagine that the pilot (?) is waving his arms in despair saying something like. "Sheep? they want me to drop sheep?
                  Great Build Steve.
                  • Gern
                    • 9213
                    Beautiful.
                    Gern
                      • 22770
                      A cracking build Steve
                        That's a really good build Steve, you'd hardly know it was 1/72. I hope mine turns out half as good.
                        • monica
                          • Oct 2013
                          • 15169
                          fantastic build, Steve and lov the paint work as well, and the sheep make it
                          nice dio
                            Great build love the sheep they really add to the overall story of the dio great job love it.
                              Looks great and nice bit of history.
