Dave's Revell 1/48 B24D Liberator
  • Dave W
    • Jan 2011
    • 4713
    #46
    [ATTACH]107540.IPB[/ATTACH]
    [ATTACH]107542.IPB[/ATTACH]
    [ATTACH]107543.IPB[/ATTACH]
    [ATTACH]107544.IPB[/ATTACH]
    I've spent a few evenings masking the transparencies.This is one model I should have bought a masking set for.The nose piece had a seem down the middle which needed sanding off and polishing.Still a bit more masking to do.
    • flyjoe180
      • Jan 2012
      • 12418
      • Joe
      • Earth
      #47
      That's great masking work Dave. You've saved yourself a few pounds, you can buy paint with that. Also, that seam removal is A1, you'd never know it was there to start with.
        • 22771
        #48
        From what you can see on the clear parts Dave that is some seriously good masking
        • Dave W
          • Jan 2011
          • 4713
          #49
          Tonight I finished masking the nose transparency. Then I glued it to the model. It's not a great fit and I ended up using superglue to hold it in place. Then I filled in the gaps with Gatorgrip. When that had dried I sprayed interior green over the framework. Then I sprayed Alclad grey primer on the fuselage. This showed up where I hadn't filled the gaps properly. So I've brushed some Mr Surfacer 500 on and left it overnight to dry. Before glueing the nose cone on, I had to fit the guns in place. Of course the inevitable has happened, I've managed to break them off!. Luckily there are spare guns in the kit that I can cut the barrels off and glue onto the model at the end of the build.
          [ATTACH]107624.IPB[/ATTACH]
          [ATTACH]107625.IPB[/ATTACH]
          [ATTACH]107626.IPB[/ATTACH]
          • yak face
            • Jun 2009
            • 13841
            • Tony
            #50
            Loving this one Dave , theyre a challenge sometimes but these old monogram kits can be so rewarding when youve got a decent result at the end. Looks like this ones been fighting back a bit more than usual but youve tamed it , cant wait to see the paint go on , cheers tony
              • 18271
              Top job on the masking.
                That's some really great work, Dave. Looking forward to the rest
                • flyjoe180
                  • Jan 2012
                  • 12418
                  • Joe
                  • Earth
                  #53
                  Looking good Dave. Guns on bombers are always a risk. One method is to cut the barrels off and glue them on after the painting is complete. Still a fiddly operation though.
                  • Dave W
                    • Jan 2011
                    • 4713
                    #54
                    [ATTACH]108443.IPB[/ATTACH]
                    [ATTACH]108444.IPB[/ATTACH]
                    [ATTACH]108445.IPB[/ATTACH]
                    Now it's painting time.I got some Humbrol 156 neutral grey on the undersides a few days ago.Tonight I masked the fuselage and put a coat of Humbrol 155 Olive Drab on.Im going to mask the wings now and spray Olive Drab on them.
                    • flyjoe180
                      • Jan 2012
                      • 12418
                      • Joe
                      • Earth
                      #55
                      Looks great Dave. Look forward to seeing how you weather the finish to that faded look.
                      • Dave W
                        • Jan 2011
                        • 4713
                        #56
                        [ATTACH]108446.IPB[/ATTACH]
                        I'm going to lighten the olive drab with a little white and spray it in the centre of some panels.I did it on my 1/24 Spitire and was quite happy with the result. I've now put a coat of paint on the wings.
                        • rickoshea52
                          • Dec 2011
                          • 4076
                          • Rick
                          #57
                          I
                          [ATTACH]119070[/ATTACH]
                          I'm going to lighten the olive drab with a little white and pray it in the centre of some panels.I did it on my 1/24 Spitire and was quite happy with the result. I've now put a coat of paint on the wings.
                          I have plenty of Olive Drab leftover from my Dakota's, I would have been pleased to post it to you!
                          • Dave W
                            • Jan 2011
                            • 4713
                            #58
                            I
                            Thanks for the offer Rick.But I've got two tins.Will be enough for this model.
                              Just caught up with this Dave it's looking good mate.
                              • Dave W
                                • Jan 2011
                                • 4713
                                #60
                                [ATTACH]108614.IPB[/ATTACH]
                                [ATTACH]108615.IPB[/ATTACH]
                                Tonight I've had a go at scratch building some brake lines for the undercarriage legs. I've used 15 amp fuse wire held in place with superglue.Should look the part after painting.
