Just finished this one .Its the new tool Airfix Spitfire MK.Vb.Ive finished it as one of the first batch of Spitfires delivered to Malta in 1942 and flown by pilot officer Buck McNair (Canadian) of 249sqdn based at Ta'Qali. the kit is the best Spitfire I've ever built.A real joy to put together.After the problems I had with the new Gnat,I approached this build differently.I test fitted everything before glueing and had no problems at all.I used an Eduard etched cockpit set.But it only needs seat belts as nothing else can be seen.I painted it with enamels and lightened the colours for a faded look.Then I used spots of oil paint drawn back I the direction of the airflow to weather it.This is a very nice kit that needed hardly any filler and I highly recommend it. The only tricky part is the undercarriage.Theres a tiny pintle/Trunnion that's glued into the wing before the wing halves are joined.Then the legs attach to these with a kind of stepped butt join.Its tricky to get the legs angled right.But the joint seems strong enough so far....
[ATTACH]117890.IPB[/ATTACH]
[ATTACH]117891.IPB[/ATTACH]
[ATTACH]117892.IPB[/ATTACH]
[ATTACH]117893.IPB[/ATTACH]
[ATTACH]117894.IPB[/ATTACH]
[ATTACH]117895.IPB[/ATTACH]
[ATTACH]117896.IPB[/ATTACH]
[ATTACH]117897.IPB[/ATTACH]
[ATTACH]117898.IPB[/ATTACH]
