Calling this one finished.Ive resisted the urge to do loads of weathering.Although it might have covered up the silvering on some of the decals.Im rather annoyed with myself about that as I'm usually careful to get them on right. The kit itself is not bad. The only real problem is the cockpit insert. If I make another one I will glue it in slightly proud of the surrounding fuselage and fill the gaps with plastic card.That way I would be able to rescribe the lost panel lines after all the sanding.Because I used a lot of filler I couldn't get a nice scribed line so left it.
[ATTACH]118356.IPB[/ATTACH]
[ATTACH]118357.IPB[/ATTACH]
[ATTACH]118358.IPB[/ATTACH]
[ATTACH]118359.IPB[/ATTACH]
[ATTACH]118360.IPB[/ATTACH]
[ATTACH]118361.IPB[/ATTACH]
[ATTACH]118362.IPB[/ATTACH]
