Well the build thread was not much more than an resume so with out further ado:
[ATTACH]30892.vB[/ATTACH] [ATTACH]30890.vB[/ATTACH] [ATTACH]30891.vB[/ATTACH] [ATTACH]30893.vB[/ATTACH] [ATTACH]30894.vB[/ATTACH] [ATTACH]30895.vB[/ATTACH] [ATTACH]30896.vB[/ATTACH]
You might recall that I thought the green was to green in the build photos, with good reason. I grabbed the wrong paint pot!!! So a bit of wet rubbing and masking, I found some Xtracrylix RAF dark green and some White Ensign dark sea grey. Much better, even if the WEM paint took two days to dry!! I might just of given it a tad too much thinners..... :-)
I must admit I am a bit miffed at the roundels on the wings. Xtradecals, set on with Micro fix and micro sol. Could be seen as the "ideal" set up.... Wrong! the darn things wrinkled and refused to flatten out. You cant see it that much but its there, and I know it!!!
Bottom was in Alclad II. Windsor and Newton's paynes grey did the dirty.
[ATTACH]35992.IPB[/ATTACH]
[ATTACH]35993.IPB[/ATTACH]
[ATTACH]35994.IPB[/ATTACH]
[ATTACH]35995.IPB[/ATTACH]
[ATTACH]35996.IPB[/ATTACH]
[ATTACH]35997.IPB[/ATTACH]
[ATTACH]35998.IPB[/ATTACH]
