From the Whirlybirds 1/144 kit, which is mainly resin with some white metal, photo-etch and vac-form parts thrown in. Not the easiest build but probably the most detailed and accurate F-4 kit in this scale, and the decal sheet was superb.
F-4J Phantom in 1/144 scale
Tags: None
I didn't think tamiya did giant sized paint pots
That is superb if you wouldn't know that was 1\144 if you hadn,t told us -
...I mean, those decals, for heaven's sake, I usually ignore the tiny ones on my builds (1/35) and ALL of those decals definitely come into that category. I am genuinely at a loss to get how this kind of quality is achieved at this scale. Well done that man!Comment
John, the kit decal sheets (actually there were two sheets of stencils and various insignia) were superbly printed and all markings settled down really well, although I did have to wear an Optivisor to apply some of them. The only slight caveat with the kit sheet was that the orange fuselage stripe was supplied in two halves, but they were both the same instead of being mirrored! As a result I had to mask and paint the orange stripe.Comment
That is truly a beautiful piece. Phantoms have some lovely curves but you have enhanced it with a suburb paint job. I have been looking at Phantoms and would love to produce something as clean as this but i was looking at 1/48!Comment
I stopped buying magazines awhile ago as I always found better stuff on forums like this but I am off camping next week so a bit of off line reading might be an idea.
Thanks for the heads up.Comment
