Completed Dave's PRU XIX Spitfire (Airfix 1/48th)
  • dave
    • Nov 2012
    • 1828
    • Brussels
    This is now completed and on time.  I have deliberately kept the weathering light.  The aircraft is pictured just before the last ever operational sortie by a spitfire over Malaya on the 10th June 1957.  From my research I gather the name "The Last!" was painted on the aircraft before the final sortie.
    Reasonably happy with this although something went a little awry with the canopy, in reality it is slightly cloudy but in these photos it looks like frosted glass unfortunately.
  • Robert1968
    • Mar 2015
    • 3596
    Wow Dave I mean wow
    I have built the same kit but nothing in comparison to yours.
    this looks brilliant ( truly stunning
    kind regards
    Robert
      That's an absolute beauty.
      • The Migrant
        • Apr 2011
        • 1268
        Lovely model Dave, the finish looks really nice   Did you flat coat over the canopy? If so you may be able to remove it with some thinners on a cotton bud, followed by carefully applying Future with a brush.
        • flyjoe180
          • Jan 2012
          • 12407
          • Joe
          • Earth
          Great build Dave. A shame about the canopy, but it doesn't detract too much from what is otherwise a fantastic result.
          • flyjoe180
            • Jan 2012
            • 12407
            • Joe
            • Earth
            Actually Dave, the canopy doesn't look too bad on closer inspection. Did you use model glue or super glue to fix it? That may have caused the frosting. I use white glue (PVA) on mine, it prevents frosting and provides a good filling agent for those pesky gaps between the canopy edge and the fuselage, as you can simply smooth it with a moistened cotton bud tip.
            • dave
              • Nov 2012
              • 1828
              • Brussels
              I was thinking of trying that! The canopy was protected for the flat coat but only loosely so some overspray may have occurred.
              Originally posted by Robert1968
              Wow Dave I mean wow
              kind regards
              Robert
              Thanks for the kind words, but I have a long way to go yet.
              Thanks Joe, as said above I may have a go at a little very careful remedial work on the canopy.
                • 22770
                Great work Dave it looks lovely, pity about the canopy though.
                • colin m
                  • 8755
                  • Colin
                  • Stafford, UK
                  She looks great Dave. But just have a look at the undercarriage again.
                  • yak face
                    • Jun 2009
                    • 13841
                    • Tony
                    Lovely looking spit dave , the colours and finish are spot on. Im sure the canopy will clean up with a bit of thinners and a cotton bud as mike says. cheers tony
                    • dave
                      • Nov 2012
                      • 1828
                      • Brussels
                      I have done  , I cannot believe I did that, undercarriage now swapped around after a bit of work.
