Revell 1/32 Spitfire Mk2a
  • Vaughan
    • Apr 2011
    • 3174
    At last I've completed a kit!! Its been a while what with continuing heart problems which I'm glad to say are all sorted now. No more interventions and following the MRI scan, back at the beginning of February, my heart is good to go.
    I've been beavering away at this one for quite a while, no build thread, this ones been built many times, so just a few cockpit details. This one's straight out of the box with some home made Sutton harnesses. Build went without any real problems. Closing the fuselage was bit of a struggle the cockpit tub was a tight fit and needed some sanding. All in all a nice well detailed kit. I see they have just brought out a Mk.IX so I may have a go at that one. Anyway this is not one of my best builds but it's a start back into the modelling, all comments welcome.
    [ATTACH]280512[/ATTACH] [ATTACH]280513[/ATTACH] [ATTACH]280514[/ATTACH] [ATTACH]280515[/ATTACH] [ATTACH]280517[/ATTACH] [ATTACH]280518[/ATTACH] [ATTACH]280519[/ATTACH] [ATTACH]280520[/ATTACH] [ATTACH]280521[/ATTACH] [ATTACH]280522[/ATTACH] [ATTACH]280523[/ATTACH] [ATTACH]280524[/ATTACH] [ATTACH]280525[/ATTACH] [ATTACH]280526[/ATTACH] [ATTACH]280527[/ATTACH] [ATTACH]280528[/ATTACH] [ATTACH]280529[/ATTACH] [ATTACH]280530[/ATTACH] [ATTACH]280531[/ATTACH]
  • Dave W
    • Jan 2011
    • 4713
    Nice build Vaughan. Your home made seat harness looks very good.
      Great work Vaughan. The cockpit looks fabulous.
      • rickoshea52
        • Dec 2011
        • 4076
        • Rick
        Good to see you back on the forum, I was just wondering that I hadn't seen any of your work for a while. Nice build.
          • 22770
          Fantastic work Vaughan.
          • yak face
            • Jun 2009
            • 13826
            • Tony
            Simply beautiful vaughan, stunning cockpit, cheers tony
            • flyjoe180
              • Jan 2012
              • 12381
              • Joe
              • Earth
              Great to hear you are feeling better and your heart is okay now Vaughan. And what a return to the forum, this is a great looking build, very inspirational. I like the subtle weathering.
              • Vaughan
                • Apr 2011
                • 3174
                Thanks guys it good to be back. Just pulled out a Trumpeter 109 trop so will be next on the bench.
                  I'm going to echo the thoughts of the rest of the lads, excellent work Vaughan, really like the cockpit
                  • colin m
                    • 8740
                    • Colin
                    • Stafford, UK
                    Perfect. I've always preferred the temperate scheme, probably because it could have been my first build as a kid.
                    • tr1ckey66
                      • Mar 2009
                      • 3592
                      Hi Vaughan
                      I'm so glad you're well and the heart problem has been resolved. It sounded so very serious and it's great to have you back.
                      The Spitfire is stunning and believe me I know this particular plastic intimately (having completed no less than 7 kits of this myself!).
                      The cockpit detail, harness etc all look just right. The paint scheme itself is flawless (as usual) and it all makes up for a great looking Spit. Nice to see an actual mk.2 for a change instead of another mk.1 backdated kit.
                      Kit-wise I think the Revell my.2 is a great kit for the money and filled a really noticeable hole in the 1/32 market. I think as an (almost) OOB build you've completely smashed it. It's a lovely looking model.
                      Question: did you find that fitting the canopy was a struggle? Every build I've done of this kit has required quite a bit of pressure applied to the canopy to get it to sit on the rails. I don't think it's anything to do with how I built them I genuinely think the fuselage is too wide for it.
                      Anyway...
                      Great work (as always) and great to have you back
                      All the best
                      P
                        That's a beauty!!
                        Magnificent work as always, Vaughan.
                        • stona
                          • Jul 2008
                          • 9889
                          A beautiful Spitfire to be sure!
                          • Vaughan
                            • Apr 2011
                            • 3174
                            Thanks again Guys.
                            Paul no real problem with the canopy. The rear section is a little narrow but if you push it down it then doesn't line up withe spine as it is then too low. So I left it and it's not really noticeable. What happened to the 7 you built? did you ever post them on the forum?
                            • tr1ckey66
                              • Mar 2009
                              • 3592
                              Here's one of them. You may have to scroll through the thread as some of the pics seem to be missing but you should get to some pics without the photoshopped backgrounds.
                              I built 3 wheels up and 4 parked. I sold the 2 with wheels retracting to a collector together with 2 parked on airfield grass bases.
                              I still have the motorised wheels up version together with 2 more on display bases. The ones I have are: Geoffrey Wellum's aircraft (92 sqd) and another 610 squadron.
                              It was quite a while ago now I built 5 together (which I featured on the forum) and then another 2 later on (after I'd sold my display models).
                              Hope you like it. I couldn't find my original build thread, it was before any aftermarket stuff became available so I was spending time modelling fabric ailerons etc.
                              I find the rear glass is too narrow to match the lines of the fuselage (although I have fixed that in later builds with some sanding and pressure on the fuselage sides). I still believe the fuselage is slightly too wide though for both the rear glass and the canopy.
                              Anyhoo, you've done a great job with yours and it's great to have you back
                              P
