1:48 Tamiya Swordfish
  • colin m
    • 8755
    • Colin
    • Stafford, UK
    My Tamiya 1:48 Swordfish float plane now completed. I started this on the 21st September, finished today - that's actually quite a quick build for me.
    It's a well documented kit with many reviews all over the web, so there's no point in me doing another one.
    The biggest issue are the Tamiya rigging 'bars'. Do they look correct ? I'm not sure, I think they are too wide, but I haven't measured them so I'm just going off the Mk1 eyeball. They are certainly more difficult to fit than my more preferred method. As the STBD wing didn't want to slide into place too well, you might notice a couple of bars are a bit 'wonky' this wouldn't have happened if I had used EZ line for rigging.
    There are two options in the kit, this is the pre-war one. All paint is Vallejo with a touch of Alclad for the collector ring.
    [ATTACH]289587[/ATTACH]
    [ATTACH]289588[/ATTACH]
    [ATTACH]289589[/ATTACH]
    [ATTACH]289590[/ATTACH]
    [ATTACH]289591[/ATTACH]
    [ATTACH]289592[/ATTACH]
    [ATTACH]289593[/ATTACH]
    [ATTACH]289594[/ATTACH]
    [ATTACH]289597[/ATTACH]
    [ATTACH]289598[/ATTACH]
    [ATTACH]289599[/ATTACH]
    One surprising thing about the completed build is, it doesn't half weigh a bit ! Any questions or comments, fire away.........
    Colin M..
    Looks superb, Colin. The rigging may (or may not) be a bit overscale, but it's a balancing act isn't it? - if it's exactly to scale, it sometimes almost invisible, even in 1/48. This build certainly captures the 'stringiness' of the Stringbag, and the finishing and detail are fantastic. It looks a lot bigger than 1/48!
    • yak face
      • Jun 2009
      • 13841
      • Tony
      Beautiful job colin , its such a characterful aircraft the old string bag . The rigging looks spot on to me , the actual bars used on the real thing were quite meaty . Cheers tony
        Colin, its looks brilliant and the rigging looks fine to me.
        If its by Tamiya i think you could almost bet money on it being correct.
        Very nice paint finish.
        • Gern
          • 9218
          Beautiful.
          • dave
            • Nov 2012
            • 1828
            • Brussels
            Cracking job, the rigging looks ok to me.
            • Dave W
              • Jan 2011
              • 4713
              Superb build Colin. And as I have said before, you are the rigging master!.
                Magnificent work! That’s a beauty
                • colin m
                  • 8755
                  • Colin
                  • Stafford, UK
                  Thank you all for having a look. It's quite an imposing model when built (it must be all that metal work) so if you fancy one, do it. I don't recall any fit issues, except fitting the STBD wing, which was a pretty major one, but maybe it was my own doing somewhere earlier in the build.
                  Exactly, and also a bit of trust that the manufacturer done their homework - so I don't have to.
                  Yes, I'm just looking at the real thing again and you're right, they are quite prominent - so yes, they probably are accurate.
                  Thanks Tony, I am getting more and more convinced that they are correct.
                  • flyjoe180
                    • Jan 2012
                    • 12407
                    • Joe
                    • Earth
                    Stunning job Colin. Enjoyed watching your build, the result as seen here is A1. Beautiful work, one to be proud of.
                      Colin mate.. one word.. Masterpiece
                        • 22770
                        Nothing wrong with that build Colin, great work.
                        • john i am
                          • Apr 2012
                          • 4019
                          Beautifully done I've been considering one for awhile. Well done mate.
                          • BarryW
                            • Jul 2011
                            • 6027
                            That is one beautiful build, nice work...
                              Fantastic! The weathering on the floats is absolutely spot on, and the overall build is, as someone else said, a masterpiece. You've set the bar high on this one, quite a standard to match!
