Hi mates!!!
The "Sondergeraet 113 SG 113" was a projected German weapon system for antitank defense in WW II.
A gun system developed by Rheinmetall-Borsig in the 75 mm caliber with a barrel length of 1,600 mm was tested as a weapon system. However, this was not arranged in the aircraft longitudinal direction firing forward, but mounted in the wings directed downward. The advantage of this shooting direction is that armored vehicles on the top have the least armor, which also smaller caliber can penetrate the vehicle armor. The cannons should be triggered by an electrostatic or electromagnetic sensor ("Foerstersonde") when flying over the target.
As test aircrafts in September 1944, two Focke-Wulf Fw 190 F-8 with SG 113 in the wings sent into the testing. It also examined the flying capability of the converted machine and the general impact of two guns in the wings. End of 1944, the machine was released in the troop testing. Any successes can no longer be determined.
For this project I took the older Dragon kit of a Fw 190 A-8 and turned it into an F-8. For the special armament I used the SG 113-Set from Airmodel.
Maybe the Dragon-190 is not a youngster but it was surprisingly easy to build. Yes, a little bit of putty and sanding was needed but that wasn't a problem.
Colors from Gunze an Revell.
The Figures are from ICM and they are really awesome. Easy to build, good fit......it was fun!!! Painted with Revell Aqua-Colors and weathered with diluted oil paint and various pastel chalks.:smiling:
Horrido.....
Stefan
Horrido.....
Stefan
[ATTACH]293820[/ATTACH]
[ATTACH]293821[/ATTACH][ATTACH]293822[/ATTACH][ATTACH]293823[/ATTACH][ATTACH]293824[/ATTACH][ATTACH]293825[/ATTACH][ATTACH]293826[/ATTACH][ATTACH]293827[/ATTACH][ATTACH]293828[/ATTACH][ATTACH]293829[/ATTACH]
