Tamiya 1/48 Brewster Buffalo
  • Dave W
    • Jan 2011
    • 4713
    This an old but still good Tamiya kit . I painted it with Xtracolour enamels and Tamiya ‘tyre black’.Weathered with oil paints. Unfortunately the white spirit I used to blend them in with has reacted with the Alclad gloss varnish. Anyone know of a gloss clear coat that doesn’t react with white spirit?. The model is finished as an aircraft of 448 sqdn RNZAF, Singapore late 1942.
    [ATTACH]317782[/ATTACH][ATTACH]317783[/ATTACH][ATTACH]317784[/ATTACH][ATTACH]317785[/ATTACH][ATTACH]317786[/ATTACH][ATTACH]317787[/ATTACH]
  • Gern
    • 9226
    Niiiice!
      • 22771
      Very nice
      • Si Benson
        • 3572
        Hi Dave,
        Nice plane:thumb2: I use/ have used, Vallejo gloss,Matt and satin acrylic varnish and can’t say I’ve had a reaction to white spirit that I’ve used during weathering.
        Hth
        • Dave W
          • Jan 2011
          • 4713
          Originally posted by Si Benson
          Hi Dave,
          Hth[/QUOTE
          I will try Vallejo gloss on my next model.Thanks.
          • rtfoe
            • 9100
            Hi Dave, Buffalos over Malaya were decimated due to British over confidence and bad intel on Japanese capabilities.
            Very nice looking build. I have always liked the funny chubbiness of the Buffalo. I would use acrylic varnishes as it hasn't reacted to any petroleum based paints that have been applied on my kits. Just make sure the paint has cured first.
            • Si Benson
              • 3572
              Word of warning Dave, It can be a bit of an arse to airbrush nicely just like the model air range. I always use several thinned coats
              • Dave W
                • Jan 2011
                • 4713
                I think I’ve used it in the past. Probably why I changed to Alclad
                  I’ve just ordered me one of these the other day, though mine will be finished as an ML-KNIL plane. Anything I need to look out for when building it? (Although, given that it’s a Tamiya kit, I kind of doubt it.)
                  • rtfoe
                    • 9100
                    Jakko...Tamiya did you say?...just shake the box and it's done. :smiling6:
                    • Dave W
                      • Jan 2011
                      • 4713
                      Nothing difficult about this kit.A nice,easy build.I replaced the roundels and fin flashes with items from an Xtradecal sheet as the red in the kit ones was a bit bright.And the aerial mast is a bit bendy so I used a piece of aluminium tubing flattened to give the correct profile.
                      • Steven000
                        • Aug 2018
                        • 2830
                        • Steven
                        • Belgium
                        Love it Dave, very nice build :thumb2:
                        Cheers Steven
                          I wasn’t really expecting anything else, but you never know
                          That won’t be an issue for me, at least.
                          That sounds like an idea I might follow.
                          • Fernando N
                            • 2448
                            Very nice one Dave.:thumb2:
                            As a frequent user of the VJ varnish line I can confirm Si's words, a couple of thin coats and letting it dry properly will give the underlying coats a good protection for your weathering.
                            • scottie3158
                              • 14221
                              • Holbeach
                              Nice result.
