E E LIGHTNING
  • boatman
    • Nov 2018
    • 14481
    • christopher
    • NORFOLK UK
    E E LIGHTNING
    Very nice looking Lighting Chris and so cool to have lights on it too.:thumb2::thumb2:
    (Edit) And the rest by the looks of it too.
    Some info on how you did those lights would be rather nice.
    That is a very nice frightening by the way.
    HI Ian the lights are 2mm led's an just built into the planes very simple an im not sure what you mean about frightening ? an thank you for your intrest
    chris
    chris
    Frightening/lightning.....
    I had figured out the the lights where little LED's it more how they are controlled I was wondering about.
  • boatman
    • Nov 2018
    • 14481
    • christopher
    • NORFOLK UK
    Thanks guys for your comments all aircraft are in 1/48 th scale
    chris
    • AlanG
      • 6296
      Very nice indeed Chris. I think you're builds would be complimented by a nightfighter lol
      • boatman
        • Nov 2018
        • 14481
        • christopher
        • NORFOLK UK
        HI Al thanks for your comments an yes it would be nice to join you guys in the nightfighter G/B bit I aint got the time as im to busy building tiger im afraid but nice try :smiling3::smiling3: LOL
        chris
        • colin m
          • 8755
          • Colin
          • Stafford, UK
          Nice builds. I'm loving the lights, do the relevant ones flash ?
          • boatman
            • Nov 2018
            • 14481
            • christopher
            • NORFOLK UK
            HI Colin yes they do flash pity I cant do a vid but I have no idea how an thank you for lookin in
            chris
            • boatman
              • Nov 2018
              • 14481
              • christopher
              • NORFOLK UK
              HI guys now IanM has asked me how the lights are made to work on the planes well i'll try an exsplain as best I can BUT YOU DO THIS AT YOUR OWN RISK
              well the first thing you will need is to buy is one of these cost £8.99 from the component - shop i'll give the address in the nxt pic Click image for larger version
              • boatman
                • Nov 2018
                • 14481
                • christopher
                • NORFOLK UK
                the address for the above Click image for larger version
                • boatman
                  • Nov 2018
                  • 14481
                  • christopher
                  • NORFOLK UK
                  A shot here at what voltage its set at an its 6v as this is a varyible unitClick image for larger version
                  • boatman
                    • Nov 2018
                    • 14481
                    • christopher
                    • NORFOLK UK
                    Now I have made the power unit from the mains powering 6v plug into a power truck as I wanted to light up more than one model in fact I have fitted 4 way micro plugs called
                    modular connectert's into the power truck a pic of the modular connecters below an with these you can cut them down to just 2 pins plugs or up to about 10 pinClick image for larger version
ID:	1091223 plug your choise
                    • boatman
                      • Nov 2018
                      • 14481
                      • christopher
                      • NORFOLK UK
                      A pic of the power truck which feeds the power to the planesClick image for larger version
                      • boatman
                        • Nov 2018
                        • 14481
                        • christopher
                        • NORFOLK UK
                        And you solder tiny dolls house wirein as its only carryin 6v to the micro plugs covering the soldered joints with shink rap to stop any eletric shorts outs the wirein belowClick image for larger version
                        • boatman
                          • Nov 2018
                          • 14481
                          • christopher
                          • NORFOLK UK
                          NXT in the model you fit a micro switch if you want for on an off an then fit a female modular plug into the model where it wont be seen I fitted mine nr the tail on the fusealarge side. if you look at the lighting pic no. 5 closely you will see where the wire goes to the female plug so on the feed wire you must have a male plug to insert into the female an make sure the wireing polarity is correct positive to positive an negative to neg
                          • boatman
                            • Nov 2018
                            • 14481
                            • christopher
                            • NORFOLK UK
                            NXT up is the 2MM LED's these you can buy from the address below Click image for larger version
                              Very nice Lightning.
