Eyup muckers, Heres a little quickie ive just finished. This is the PM models 1/72 Lippisch P13a Ramjet fighter. This fascinating aircraft was a late war german project that didnt see production.The shape was tested as an unpowered glider and the ramjet theory tested successfully in the laboratory. Wind tunnel tests showed the shape to be stable at speeds up to mach 2.6 ,although with the plain inlet the max speed would have been more like mach 1 due to shock waves building up in the inlet (a variable shock cone as on various later jets ie. mig 21,su7, would have allowed higher engine output and thus higher speed) The most amazing thing about this aircraft is that it was intended to be powered by granulated coal, burnt by gas jets in a rotating drum basket(coal being a cheap readily available fuel , other fuels suffering in their supply at this late stage of the war) the resulting hot gases would have been compressed by the forward motion of the aircraft and by doing so generated more power which was exited through the slit at the back. The minimum speed necessary to create the ramjet effect would have been provided by a small rocket motor. The p13a was intended as a limited range point interceptor in the same vein as the ME 163, but would have been quite a bit faster. The kit is very simple and has only 11 parts (count em!) ,4 of which are the ground trolley! I only added some belts, a headrest and a rudimentary instrument panel , and also had to build up the cockpit opening and create the canopy frame ,as the canopy was undersized and had a few marks round the edges from the sprue attachment. Right then , for those of you still awake , heres the pics!!! cheers tony
[ATTACH]40700.IPB[/ATTACH]
[ATTACH]40701.IPB[/ATTACH]
[ATTACH]40702.IPB[/ATTACH]
[ATTACH]40703.IPB[/ATTACH]
[ATTACH]40704.IPB[/ATTACH]
[ATTACH]40705.IPB[/ATTACH]
[ATTACH]40706.IPB[/ATTACH]
[ATTACH]40707.IPB[/ATTACH]
[ATTACH]40708.IPB[/ATTACH]
[ATTACH]40709.IPB[/ATTACH]
[ATTACH]40710.IPB[/ATTACH]
[ATTACH]40711.IPB[/ATTACH]
