Revell Spitfire Mk1, 1/32 Scale
  • BarryW
    • Jul 2011
    • 6027
    This aircraft was flown by Battle of Britain ace, Bobby Oxspring. He was shot down late in the battle flying this aircraft, which crashed in Capel, between Dover and Folkestone. Oxspring bailed out, went on to score more victories and survived the war to reach high rank in the RAF after the war.
    The kit suffered from severe warping of the wing which gave me serious problems and it does affect the look of the model even though I was able to correct the worse of it with the use of hot water!
    The base kit is a Mk 2 but it is easy to get a Mk 1 out of a Mk 2 kit. There are, however, several inaccuracies in the kit that needed correcting with a.m. parts, most noticeably the oil cooler. The kit had fabric looking ailerons that needed replacing but thanks to the wing warping, I ended up using the kit parts. The difference in appearance is minor after a little sanding. The cockpit door was replaced as was the instrument panel and wheels. I used metal undercarriage legs as the kits ones are very fragile and an axle broke. The Eduard detailing set was very good and is recommended for this kit as it does make a big difference. I also got a resin am seat and armour plating.
    The kit is cheap, the only good thing about Revell (apart from decent decals), but once I got the aftermarket, I spent more than I would need to spend on a Tamiya Spitfire at four times the cost of the Revell kit, with which I would have got a better result, but not a Mk 1sadly!
    anyway some pictures.....
ID:	1138331Click image for larger version
ID:	1138332Click image for larger version
ID:	1138333Click image for larger version
ID:	1138334Click image for larger version
ID:	1138335Click image for larger version
ID:	1138336Click image for larger version
ID:	1138337Click image for larger version
ID:	1138338Click image for larger version
ID:	1138339Click image for larger version
ID:	1138340Click image for larger version
    Now, below is the reason I wanted to build the aircraft - it is pictured alongside a set of cufflinks made from the casing of this aircraft's Merlin engine.
ID:	1138342Click image for larger version
ID:	1138343Click image for larger version
  • Neil Merryweather
    • Dec 2018
    • 5189
    • London
    Another winner from the master!
    Lovely stuff, Barry.
    • Nicko
      • Apr 2019
      • 1403
      • Nick
      • East Anglia
      Still turned out really well, Barry, despite the trials it gave you.....
      Nick
      • Vaughan
        • Apr 2011
        • 3174
        Barry as I said in your build thread it has turned out well you wouldn't know that you had had any issues. I think maybe you need to give the Revell kits a rest now and hopefully the Frogfoot won't give you any problems. Once again a great build with a nice paint job and subtle weathering.
        • BarryW
          • Jul 2011
          • 6027
          Yes indeed. No Revells in the stash now. I might get their Me262 in due course.......
          • stona
            • Jul 2008
            • 9889
            Beautiful Barry!
            It's a tremendous result and well worth the hard work with the Revell kit.
            • stillp
              • 8093
              • Pete
              • Rugby
              Great result Barry!
              • adt70hk
                • Sep 2019
                • 10409
                Barry
                As the others have said a top notch effort as always. And nice to have the extra addition of the cufflinks too.
                ATB
                • flyjoe180
                  • Jan 2012
                  • 12407
                  • Joe
                  • Earth
                  Beautiful result Barry. A poignant build with the cufflinks.
                  • Steven000
                    • Aug 2018
                    • 2828
                    • Steven
                    • Belgium
                    Great build Barry, never can get enough of Spitfires :thumb2:
                    Steven
                      • 18907
                      That looks great Barry. I particularly like the splash of colour the Bakelite seat gives to the interior.....weathering is also spot on. Really impressive!
                        • 18269
                        Nice result Barry.
                        • minitnkr
                          Charter Rabble member
                          • 7539
                          • Dayton, OH USA
                          A beauty. Cuff links are a nice touch. PaulE
                            • 15703
                            Hi Barry
                            That looks an excellent result. As you said the cost of the necessary after market stuff raised the cost to Tamiya level but you have what you wanted and it looks really nice. The cockpit is stunning.
