Having bought some Alclad stuff, I needed a suitable model to experiment on. Hence the Academy 1:72 Mustang retailing at about £5.99 fitted the bill perfectly. This would have a polished aluminium fuselage and normal aluminium wings.
The polished aluminium needs a gloss black base to make it work, so, to make life easy I thought I would use the Alclad gloss black primer. What a waste of time. What ever surface I sprayed this on, it remained matt black. In the end I used a large tin of 'average everday' gloss black which worked great. Unfortunately, after so many coats of the Alclad 'gloss' black I lost a lot of detail on the fuselage.
As we know, surface prep has got to be 100% with alclad, and so I went over and over the model again and again. But still a couple of small seams still showed up under the alclad ! I'll use a magnifying glass next time.
So, there was no WIP thread, the kit goes together very easily with a nice level of detail for the price.
If you think the landing gear doesn't quite line up, you would be correct, after finishing the model, I dropped the thing ! Anyway, I have now discovered what many before me have already done so, alclad is brilliant. I thought a NMF model could be a bit plain (no pun intended) but, I'm converted. Well, what can I do next, can anyone recommend the Tamiya 1:48 Mustang ?
[ATTACH]37956.vB[/ATTACH][ATTACH]37957.vB[/ATTACH][ATTACH]37959.vB[/ATTACH][ATTACH]37960.vB[/ATTACH][ATTACH]37961.vB[/ATTACH]
Colin M........
[ATTACH]42081.IPB[/ATTACH]
[ATTACH]42082.IPB[/ATTACH]
[ATTACH]42083.IPB[/ATTACH]
[ATTACH]42084.IPB[/ATTACH]
[ATTACH]42085.IPB[/ATTACH]
[ATTACH]42086.IPB[/ATTACH]
Colin M........
