Finished at last! My first, and probably last, 1/144 kit. Highly recommended if you like tiny stuff - very little cleanup needed, no fit issues at all, very little filler needed, nice crisp moulding on the canopy frame so it was fairly easy to mask. Instructions get a bit vague when it comes to the underwing stores, there's no guidance on which weapons are appropriate to the RAF or German schemes, or which stores use which pylons, so I had to do a bit of guesswork research.
Should have been an easy paint job as it's the same colour all over, but my jar of Tamiya XF19 seems to come out a slightly different shade every time I use it, in spite of stirring with a Badger stirrer. I damaged the paintwork on the starboard side of the vertical stab after fitting the decals, so touched it in, but it looks pretty awful.
Most of the decals were a waste of time as they're invisible - can you see any of the 36 "NO STEP" decals? Thought not! There are also two decals on each of the 4 fuselage-mounted AMRAAMs, which I'd applied in accordance with the instructions, but they're on the side of the missile that's glued to the fuselage!
Thanks for watching
Thanks for watching
