Hi guys,
I started these two planes a while ago but unfortunately they got shelved,
I managed to put in the final effort and got them finished now. :thumb2:
These ICM kits have a great 'price/satisfaction value' in my opinion.
Kits used :
Mentionable adaptations :
Many thanks for looking in!
Keep it safe & have fun
Steven
Kits used :
- Bf109 F4 : ICM 1/48
- Bf109 F4 : ICM 1/48 (F-4Z/Trop)
- Kübelwagen with figures - Tamiya 1/48
- Molded nose-canons were replaced with small tube.
- Sand-filter (Trop) was cut up and made 'opened' as I preferred the look of it (should be closed on the ground but perhaps got jammed)
- New antenna masts were cut from sheet of Aluminium, as the kit part was too flexible to connect a wire to.
- Engine covers received inside detail made from pieces of stretched sprue.
- Engine pipes/cables were made from stretched sprue.
- The swastika for the 'Trop' aircraft was masked with Tamiya tape, my first attempt was plain black but I redid the masking and got the white outline on too.
- The number '14' was masked from Tamiya tape (because I didn't like the decal with black outline).
- Base is made from 18mm Mdf (3/4").
Steven
