Well, here it is, warts and all - and there are a lot of warts!
It was an interesting exercise, but much harder than I expected! I kept on wanting to get the sanding stick, plastic card & filler to work.............
The Humbrol tube glue was a bit of a flop, it seemed to have lost it's adhesive properties with age, so I had to resort to Contacta.
The model itself? - pretty simple, very little detail, but the fit was surprisingly good - the engraving on the inside of the fuselage said 1975 - so 46 years old!
It was quite refreshing, snipping & gluing, not worrying about joint lines & painting, but not a thing I'd do regularly. One tool I did miss most, was a pair of tweezers! With fat fingers, some of the smaller parts were hard to get hold of.
If I was doing this again, as a real display model, aside from the primer paint & decals, then just on the building, drills, sanding sticks, rescriber, filler, maybe a PE instrument panel, Contacta glue, TET, PVA ( for the canopies ) would be used.
Now, at least I have a new paint test canvas - just have to lose all the fragile bits wheels, propellers etc..................
