Completed: ICM Dornier Do17Z-2 1/48
  • BarryW
    • Jul 2011
    • 6029
    This kit is not as good as previous ICM kits I have built. But, it is the oldest tooling and ICM are well known for how they have improved over the years.
    The result is a reasonable model but the poorly designed undercarriage Is quite weak and I don’t expect it to last long.
    Barry,
    very nice! You don't realise how big it is, until you see it 'in hand'! The problem with the undercarriage is probably that ICM have faithfully reproduced the parts to scale - I've come across this with Zvezda models as well - a part may be true to scale, but it's plastic not a high strength alloy!
    • BarryW
      • Jul 2011
      • 6029
      Barry,
      You are right in that ‘true to scale’ can often create issues but that is not it with this kit. It is entirely down to the engineering. The legs butt join inside the nacelle and they have to marry up to the cross braces. There are no positive locations on either. It results in a weak join. If I cemented it all together at an earlier stage it would have been easier, but not much stronger and would certainly not have survived handling in one piece.
      • Nicko
        • Apr 2019
        • 1423
        • Nick
        • East Anglia
        Looks lovely Barry. I have this one to build at some point - perhaps I should attempt a 'wheels-up' version...
        Nick
          • 15744
          Hi Barry
          Another top quality build.
          • Gern
            • 9226
            Beautiful
              • 18271
              Nice one Barry. Might not be one of their newest but it built up nicely.
              Shame about the iffy legs. No aftermarket for them?
              Still it looks great.
              • adt70hk
                • Sep 2019
                • 10428
                Hi Barry,
                As I said before, this has turned out very well indeed.
                Well done but a shame about the undercarriage as you said.
                ATB.
                • PhilJ
                  • May 2015
                  • 1145
                  You've done a cracking job Barry, greenhouse looks amazing
                  • rickoshea52
                    • Dec 2011
                    • 4076
                    • Rick
                    Excellent result Barry.
