B17 Memphis Belle
    • 18271
    That looks like a great build Ole. As Steve pointed out it is a bit shiny for a painted finish. Also the weathering is a bit heavy and not sure about using brown. As others have pointed out in other aircraft threads Aircraft where normally kept pretty clean. The most prominent things being the exhaust staining and machine gun smoke on wings or noses.
    The most prominent form of weathering on an aircraft is fading/bleaching due to age and the effects of weather. Oil from engines, hydro lines and the such.
    A good colour for picking out panels and the like is a good deep grey. (I use an oil paint 'panes Grey' or if I need a darker colour good old black).
    BUT the big thing to remember is you are building for your own enjoyment so if you are happy, keep on doing what you are doing.
    skål
      thnx for info ian duly noted and thnx for that lancy will look alot nicer i`m hoping
        the glossy look on the aircraft didnt pan out like i hoped it was supposed to look wet and damp in places as we r in blighty hahahahahaha oh well:cheeseygrin:
        • flyjoe180
          • Jan 2012
          • 12429
          • Joe
          • Earth
          #19
          I can see the exhaust staining on the Lancaster now, thanks for the pictures.
          • Alan 45
            • Nov 2012
            • 9833
            #20
            that looks great and if im not mistaken that's revels 1/48 Memphis belle's kit. ive built one and it would be goog to compare the two, I also think I went a bit hay wire with the weathering did you find that the kit needed quite a lot of trimming? still I like the paint job :welldone:
              Very very good and a cracking first build. I can partly agree with the weathering comments but it doesn't look "unrealistic" just "heavy" - nothing wrong with that if that's how you want it. (Coming from the guy who uses weathering to cover up botched paint jobs haha)
              Otherwise a brilliant start!!
              Stuart
                It looks awesome!
                And the 1/48 scale is just, well, huge doesn't seem to fit the description. Massive more like it. I know we generally like to take photos of completed models trying to get the affect of real scale, but with a kit like this, it would be nice to have something real life, like a can of coke or box of ciggis nearby or on top to get the true massiveness of the kit. I don't think a 1/48 B17 would fit on my work model table, Never mind finding a place to show case it. Well done!
                And I'm glad there is two B17s that popped up on the threads completed recently, as I have my own 1/72 Memphis Belle waiting down the line and i'm sucking all the tips and advice and pics up like a sponge.
                How does one weather the exhaust streams with pastels, in degrees and build it up? Do you put a wet coat of something clear on and dust the pastel on the wet streak and repeat after drying? That's as far as I can imagine how to do it.
                Frikkie
                  sorry to for taking so long,just noticed this lol,i used pump action hairspray,not aerosol spray,then added pastel to the colouration i liked,made a bit of a boob on the wings,tried to make it look wet in places,but failed big time,though i`m very new to model building and will experiment,with everything till i get the answer i`m happy with
                  mobear
                    Just found this Ole was on vacation when you posted it originally. Really good effort for a first build,ca'nt add much to whats already been said about the weathering. A very difficult first subject to say the least and you handled it very well! One thing I would suggest would be experiment on scraps before going at it on your build,a lesson that I learned the hard way several times. Looking forward to your next build ,cheers Trey
                      Hi Ole missed this first time around, you sound disappointed with your efforts don't that is a great first attempt. As to weathering tips and modelling in general go through Flory's free videos in YouTube, they are very helpful, here is the link if you don't already have it
                      His weathering washes are excellent when you maybe just want to highlight panel lines as I did in my Sea Vixen, or if you want a really dirtly effect as my Tornado. Best thing is if you use a gloss varnish coating as a base; if you don't like what you have done, you can take it off with a dampened kitchen tissue and try again.
                      Main thing is practice makes perfect. Cheers Derek
                        cheers for the link Derek,and thanks for the input,if its modern then i think quite clean will be better for those aircraft,older aircraft i like dirty lol
                        mobear
                        • spanner570
                          • 15428
                          #27
                          Excellent first build ole, you should be well happy, not slightly disappointed. With all the great advise and encouragement you've received from the boys, the next aircraft will be even better.....That's what makes this place so good, the willingness to help each other.
                          Ron
                          • colin m
                            • 8763
                            • Colin
                            • Stafford, UK
                            #28
                            Most people (well me certainly) don't bother with weathering on there early models. So well done you for having a go.
