Cheers Andy. Agreed, it does look a bit menacing.
Cheers Ron. Fun Factor is important for a hobby! :smiling:
Thanks John, glad you like the Zero
Thanks Chris, appreciate your comments. It wasn't grubby in the references, and it seems the ground crews took time to look after these early war navy aircraft. So tidy and clean is what I went for.
Cheers Pete
Cheers Paul
I splashed out on Edward masks Colin. The first time I've bought masks, not because of the number of panes, but because Airfix have slight curves in each section. I tried to mask with tape before I bought the mask set but the slight curves defeated me. I have a Hasegawa A6M5c kit which does not have the curves. I think Airfix exaggerated them a little, and Hasegawa hasn't bothered at all. Here's the canopy of the original A6M at the Auckland War memorial Museum
Highly recommend kit Tony. All the errors were mine, apart from the blanking off for the antenna mast on the canopy, and the main landing gear was testing. The original issue of this mould correctly has the mast. Same instruction sheet, different scheme.
Cheers Pete
Cheers Paul
