I brought this kit to see if I could do a better job as I have built a number all with varying degrees of success.
So this time I focused on the the aircraft it self with working bits an after thought.
Here's the results
Very nice model, Peter. :thumb2:
I guess clear plastic/see through kits require a very careful handling of glues and a more than perfect planning and executing of masking/painting as, I suppose, they are quite unforgiving.
