HobbyBoss Focke Wulf TA 152
  • Easyrider5258
    • Dec 2023
    • 79
    Only my 2nd build in the last 40 years, still learning, my airbrush is to big a nozzle for fine detail (Iwata Neo 3.5 nozzle) its great for getting lots of paint on, have obtained a 2nd smaller nozzle airbrush (Harder & Steenbeck size 2 nozzle) dabbing on the mottled camo dont work for me, taken more pics than last time, kit built up ok, decals difficult, tended to disintegrate, had to paint on red/yellow bands in the end. Amma hobby Hurricane 1/48th Mark IIc next, thinking I will do the all black one
    FW TA152.4 by Mark Handley, on Flickr
    FW TA152.3 by Mark Handley, on Flickr
    Fw TA152.2 by Mark Handley, on Flickr
    Fw TA152 . 1 by Mark Handley, on Flickr
    • 22770
    Very nice indeed.
    • langy71
      • 1947
      • Chris
      • Nottingham
      A very nice finish for your second model in 40 yrs,
        Mottling without using an airbrush can be very time consuming - I have used tiny little irregular pieces of sponge, held in tweezers, dipped in well diluted paint - then blotted on paper until almost dry - then touched gently to the model ( not dragged, just touched ) - change the sponge occasionally to get a different shaped mottle - Repeat - Repeat. Leave overnight, look at your efforts in daylight, and continue....................
        Finally seal all in with varnish - it can take quite a while, and you always have the nagging doubt of " too much?", or " too little?"
        • Del640
          • May 2020
          • 1151
          Very nice!
          • adt70hk
            • Sep 2019
            • 10400
            Very well done indeed for only your second kit in 40 years!
            • Tworrs
              • Jan 2022
              • 1980
              • Garry
              • New Zealand
              Very nice Mark, great result
                • 15653
                You can be happy with that result. Well done.
                • flyjoe180
                  • Jan 2012
                  • 12381
                  • Joe
                  • Earth
                  Very nicely done Mark
                  • colin m
                    • 8740
                    • Colin
                    • Stafford, UK
                    Nice job Mark.
                    • HAWKERHUNTER
                      • Feb 2012
                      • 1555
                      • Steve
                      • Halifax, West Yorks.
                      Well done Mark. Another method I have used for this type of camouflage is to make a small template. Use some plasticard and cut out some small random shapes. Then hold the template up to the model and spray through it. Try it on some scrap paper before you go to the model and see if you get the effect you are after.
