the screw holes in the wings and fuselage have tiny plastic covers,they are all different thicknesses but i did not realise until far too late and would of saved myself a hell of a lot of sanding down(only one is obvious as it has a panel line in the middle of it. numbers on them and on the instructions would of made all the difference.
I've given up on them. Even if you get them in the correct place you still need to fill them. I just wack some Milliput in the hole and then file/sand it flush. Frankly it's easier than arseing about with the little "discs".
