1/72 Fw 190 D-9
  • selrach
    • Apr 2009
    • 180
    1/72 Fw 190 D-9
    Mates, Here is a Hasegawa 1/72 Fw 190 D9 which I hope you will like representing a plane of Oskar Römm of JG 3 in 1945 in typical camo pattern. Again it is painted with rough edged masking techniques. I tried my best to reproduce the spot pattern of the only photo of Römm’s plane that I had at the time, of the starboard side. The view of the port side was unknown to me so I had to ‘wing it’. Any time the paint was less than smooth I wet sanded the affected area with 10000 grit sanding film. Cockpit details such as head armour, seat belts made of tin foil with detail set buckles, instrument panel with dials, throttle levers etc. were added. Also included were a DF loop and antenna of thin wire and cannons of small steel tubing. The machine guns and little scoop on the cowl were hollowed out with a hand drill. Other than that, the plane
    is *out of the box*.
    If I were to do it again there are a number of things I would change. It is now known the spot pattern on the tail indicates the plane was a 210xxx or 211xxx series aircraft originally built by Focke-Wulf. The mottle spots were most likely dark brown 81 and leaf green 82. A port side photo of the plane has been published so it would fun to try to replicate its pattern as seen in the photo. The shade atop the fuselage and wings looks light enough to have been solid grey 75, although maybe a light version of green 82 was used as well. There looks to be an unknown darker colour covering the wing root area and perhaps the wing tips. Swatstikas should be smaller and the chevrons perhaps narrower. The underside of the wings I painted solid 76, but we know now that usually only the front part of the underwing , as well as the control surfaces were painted with 76 or maybe greenblue. The rest was left bare metal. Also the top colour of the wing was wrapped over the front edge of the wings and wing tips. Lastly, I think a thin vacu-formed rear canopy would look more realistic. Next time!
    [ATTACH]20214.IPB[/ATTACH]
    [ATTACH]20215.IPB[/ATTACH]
    [ATTACH]20216.IPB[/ATTACH]
    [ATTACH]20217.IPB[/ATTACH]
    good job sir!
    • stona
      • Jul 2008
      • 9889
      Nice looking "Dora" you've got there,in 1/72 as well. I've always thought the D series was one of the best looking aircraft of the war.
      • yak face
        • Jun 2009
        • 13840
        • Tony
        nice job selrach, keep em coming! cheers tony
          Nice paint job, funny is it how we all finish a model, and instead of being happy with it we think of things we would change the next time.
          Keep up the excellent work Derek
          • selrach
            • Apr 2009
            • 180
            Originally posted by \
            good job sir!
            Thanks Mr Tiger!
            • selrach
              • Apr 2009
              • 180
              Nice paint job, funny is it how we all finish a model, and instead of being happy with it we think of things we would change the next time.Keep up the excellent work Derek
              Dear Derek, Thanks for your comment. This plane turned out to be one of the better ones, so I am pretty satisfied with the results generally. But it is also nice to have some future challenges, especially when new knowledge about a certain type of plane comes to light or one learns of a new technique or two from one of you guys.
