Well after a LONG build ive finally finished it on the last day, nothing like cutting it fine!After all the buzz when the build started, i went on holiday and when i got back just couldnt seem to get motivated, being sidetracked by other builds and just a little bit fw190 overloaded, but eventually i got moving and here is the result. As you may have seen on the build thread the kit is quite old and lacking detail in most major areas, but in its favour it has some lovely restrained raised rivetting and is simple and reasonably accurate. The hardest parts were making the cockpit and wheel well details and fabricating the lightning flashes from bits of spare decal . I had originally hoped to do the all yellow cowl version of grafs machine but realised mid build that version had extra supercharger scoops each side of the cowl,so stuck to the earlier incarnation. here are the pics, cheers tony
[ATTACH]24702.IPB[/ATTACH]
[ATTACH]24703.IPB[/ATTACH]
[ATTACH]24704.IPB[/ATTACH]
[ATTACH]24705.IPB[/ATTACH]
[ATTACH]24706.IPB[/ATTACH]
[ATTACH]24707.IPB[/ATTACH]
[ATTACH]24708.IPB[/ATTACH]
[ATTACH]24709.IPB[/ATTACH]
[ATTACH]24710.IPB[/ATTACH]
