Completed Spitfire XIV
  • stona
    • Jul 2008
    • 9889
    This is PCM's 1/32 kit. You can see how I got on with it here.
    I've completed this aircraft as RB 188,DL*K,of 91 Sqn. RAF. There is some confusion about the identity of this aircraft but this one certainly had the "c" wing."Brunhilde" was flown by V-1 ace Flight Lieutenant H D Johnson,amongst many others,on several occasions. H.D. Johnson was also nicknamed "Johnny" but not to be confused with the more famous J E Johnson.
    I've done it around about the second week in June 1944 with full invasion stripes,showing a bit of wear and tear.
    Here's a quick "walkaround"
    The high back,late Mark,Griffon powered Spitfires might not have been the best of the bunch,but they are certainly as beautiful as any other Spitfire.
    They look like a MkV that's been at the steroids
    A stunning piece of work Sir, 5 Star from me. Cheers Derek
    • aaron
      • Oct 2011
      • 2019
      Fantastic outcome Steve.
      Love the nose art.
      • BarryW
        • Jul 2011
        • 6010
        Brilliant build Steve....
        • michaelm
          • Dec 2011
          • 437
          Great job Steve, very nice indeed.
            Superb. What a gorgeous aircraft.
            • yak face
              • Jun 2009
              • 13840
              • Tony
              Simply beautiful steve. The weathering on the stripes is spot on , and the rest of the build is superb , big 5 from me , cheers tony
                • 18266
                That is a beauty Steve.
                Love it.
                Big five from me as well.
                IanM
                  absolutely awesome,and now lost for words.did they use this spits to tap the wings of doodlebugs to throw them off?just wondered
                  mobear
                    Another splendid example Steve. Is the nose art decal or hand painted. By the way, have you started your Dragon ME109 yet. Have made a tentative start on mine but have read somewhere of fit problems wih the engine cowl ! but hav'nt reached that stage yet. Always nice to see your work. Regards, Pete
                    • stona
                      • Jul 2008
                      • 9889
                      Thanks chaps,I appreciate the nice comments and am glad you like it. These PCM kits really look accurate to my untutored eye and are well worth the effort to build them.
                      Ole,these Spitfires were used in an anti V-1 role. These operations were code named "Diver" and aircraft like RB 188 engaged on such missions had the so called "gem" modifications to their Griffon engines. As far as I can establish this was some kind of carburettor tweak but I'm not a mechanic.
                      There are a couple of cases of "tipping" of V-1s. No contact was actually made,the airflow under the Spitfire wing disrupted that over the V-1 wing at close proximity,depriving it of lift,destabilising it and causing it to tumble. The Spitfire pilot would position his wing above that of the V-1,not below it as most people believe. More usually the V-1 would be engaged,from behind,with machine gun and cannon fire. Not for the faint hearted as the attacking aircraft would inevitably be uncomfortably close to any resulting explosion.
                      Pete,I haven't started on the 109 yet. I was planning to do something completely different,the old Monogram Eastern Airlines DC-3 kit but mine is minus instructions and I need to find some as it's not an aircraft I'm familiar with.
                      It's a toss up between the Cyber Hobby Bf 109 and a Hasegawa Fw 190 D-9 done as Theo Nibel's famous aircraft,downed by a bird strike on operation Bodenplatte. The latter is a project I've had in mind for a while.
                      I'd like to do the Bf 109 as von Werra's aircraft but have yet to look for decals (or masks). I've not heard of cowling fit problems on the Cyberhobby 109,there were definitely problems fitting the cowlings around the engine on the Eduard version. I guess we'll find out soon enough
                      • spanner570
                        • 15391
                        Really nice model Steve. Spot on......Big 5!
                        I always like your releases 'cos not only do you give a bit of history, you always answer any questions, giving yet more info. and even more history...And we thank you for that.
                        Ron
                          thnx for that info steve,i did wonder lol
                          mobear
                          • stona
                            • Jul 2008
                            • 9889
                            Thanks again.
                            It's as much about the history as the model for me Ron!
                            I forgot to answer the question about the nose art. It's a decal and like all of those for this model (by Cartograph) is very good.
                            Here's a pathetic attempt at some close up photography! You'll get an idea I hope.
                              Originally posted by \
                              Thanks again.It's as much about the history as the model for me Ron!
                              I'm liking that, very much
