Completed -Airfix 1/48 Spitfire mk1.
  • Dave W
    • Jan 2011
    • 4713
    Not another Spitfire i hear you all say?.Well,i hadn't built a Spitfire for almost 20 Years.Then i got two for Christmas.The mk9 Was first and now the mk1.
    . Not the best kit on the market.But my daughter gave it to me so here it is.I decided to do the early mk1 version.This one belonged to no.19 sqdn at RAF Duxford.The first squadron to operate the spitfire.The no.19 was painted on the fin for one day only,October 31st 1938.This was so an official photographer in a Blenheim could take aerial photo's.The kit went together ok.Had to be careful with the wing to fuselage join as its not a very good fit.I added a scratch built ring sight in the cockpit as the kit doesn't come with one.And I added some 'Lion Roar' seat belts bought from John.I painted it with Xtracolour enamels,because I already had the colours.Made it slightly dirty with Florymodels dark dirt wash.Not too dirty though,as its a pre war aircraft and would have been kept clean.As usual,I managed to knock the pitot off.So that's got to be refitted.And I've just noticed I haven't painted in the light under the fuselage,so will have to do that.
  • Vaughan
    • Apr 2011
    • 3174
    A very nice clean build Dave the camo has come out really well.
    • yak face
      • Jun 2009
      • 13836
      • Tony
      great job dave , not very often we see the first version of the mk1 with the 2 blade prop and straight canopy . It looks a very nice kit , did it build well? tony
        • 22770
        You have done a great job on that one Dave like Tony say's you don't see this type very often
        • Dave W
          • Jan 2011
          • 4713
          Quite an easy build. The wing to fuselage joint wasn't brilliant .It needed a plastic card shim under the front of the wing.Otherwise there would have been a step up from the fuselage to the wing.I should have scribed the control surfaces a bit more as well,as they don't show up very well in the photo's.Not bad for an old kit though.
          • colin m
            • 8741
            • Colin
            • Stafford, UK
            Very nice. These are the colours I like to see Spitfires in.
            • yak face
              • Jun 2009
              • 13836
              • Tony
              Old kit you say? I thought it must have been a new release judging by the box and your build , top work mate , cheers tony
                I think you've done a spot on job with the weathering, as you say this particular one, being cleaned up for the picture, would be looking it's best. It's interesting to see how the large twin bladed prop and the straight canopy makes it look dated.
                Great model and great pictures.
                • michaelm
                  • Dec 2011
                  • 437
                  Very nice Dave, you know I've never built a Spitfire, maybe I should. M
                  • Dave W
                    • Jan 2011
                    • 4713
                    If you want an early mark the Tamiya kits the one to go for.I built one when it first came out.And I remember it as a very nice kit.Much better than this one.
                    • flyjoe180
                      • Jan 2012
                      • 12390
                      • Joe
                      • Earth
                      Super work Dave. I did the Hasegawa 1/72 Spitfire with the two blade prop and flat canopy a while back. Your Airfix rendition with the yellow bordered roundels makes it more colourful and clean looking. Super work.
                        • 18266
                        Nice one Dave. You have made a good job of it. One thing though, that antenna post. It looks a bit thick ad flat, wasn't it round on the MkI ?
                        I think I still have a vacant spot where there should be an early MkI on my shelf.
                        Five stars on there way.
                        • Dave W
                          • Jan 2011
                          • 4713
                          Nice one Dave. You have made a good job of it. One thing though, that antenna post. It looks a bit thick ad flat, wasn't it round on the MkI ? I think I still have a vacant spot where there should be an early MkI on my shelf.
                          Thanks Ian.The aerial is the right shape if you compare it to the photo of the real aircraft.Its maybe a bit thick.Thats Airfix's moulding though.I could have replaced it but think its ok myself.
                            • 18266
                            Can't agree there Dave, to me the Aerial in the photo looks round. The Aerial post on an early mark one's (the first batch of 310; K9787 to L1096 ) was round, the wire coming up through it. This was later replaced with the tapered profiled mast with the prong at the rear.
                            The wire coming out through the fuselage, attaching to this prong, then back to a small post on the top of the tail.
                            • Dave W
                              • Jan 2011
                              • 4713
                              Can't agree there Dave, to me the Aerial in the photo looks round. The Aerial post on an early mark one's (the first batch of 310; K9787 to L1096 ) was round, the wire coming up through it. This was later replaced with the tapered profiled mast with the prong at the rear.The wire coming out through the fuselage, attaching to this prong, then back to a small post on the top of the tail.
                              Don't wish to get into a rivet counter argument so will take your word for it.My daughter would probably say 'Whatever!'.Its just a model and is good enough for me.Whilst we are rivet counting,any idea what that contraption is mounted on the fin leading edge in the photo of the real aircraft?.
