Revell 1/48 Lockheed Ventura
  • Dave W
    • Jan 2011
    • 4713
    Just finished this kit.Its a new moulding by Revell and is superb.The areas that can be seen like the cockpit ,bomb bays and wheel wells are very nicely detailed.And all the parts fit together with no problems at all.Ive made a bit of a mess of the paint work around the dorsal turret so will have to go over it again.I wanted to use the octopus decal but it doesn't completely cover the area.Revell give you a paint mix to match the colour and I can't get it quite right.If I did this kit again I would use the decal as a template to mask the octopus and spray it on.One thing I'm pleased with is the aerial wires .I always struggle to do these without getting glue on the paintwork.This time I drilled holes in the fuselage and tail fins and attached fishing line with superglue gel.Left overnight to dry then made an Ariel mast from stretched sprue,cut a slot in the top and glued the 4 pieces of line to it.Anyway,it's a great kit.Revell at their best.Just don't look too closely at the octopus!.
    • 22770
    That looks great Dave can't see anything wrong with the Octopus 5 stars from me
    • Gern
      • 9218
      I agree. *****
      Gern
        Yes it looks a 5 star build to me as well. Really like the aerials and the paint work looks awesomel. Very nicely done Sir!!!
          Looks great Dave!
          Perfect paint work, without doubt, a five stars build!
          Polux
          • flyjoe180
            • Jan 2012
            • 12400
            • Joe
            • Earth
            Dave, super work on this Ventura, it looks fantastic.
            • yak face
              • Jun 2009
              • 13841
              • Tony
              Top job dave , a definite 5 star build and from where im sitting the octopus looks spot on. cheers tony
                • 18269
                Nice one Dave.
                • mossiepilot
                  • Jul 2011
                  • 2272
                  You've done yourself proud Dave, I'd be well pleased with that and so should you.
                  Definately a 5 star build.
                  Tony.
