21st century bf109
    21st century bf109
    here is another for telford
    [ATTACH]72133.IPB[/ATTACH]
    [ATTACH]72134.IPB[/ATTACH]
  • AlanG
    • 6296
    Wow that's great. Is that the G14 kit?
      • 18266
      Nice one Andrew.
      • Dave W
        • Jan 2011
        • 4713
        Nice build.Looks like a G6 to me.
        • spanner570
          • 15391
          Great build Andrew.
          G-14 it is Allyne.....I have the same kit in my stash.
            it is the g14 and i have just noticed the wonky decal on the spinner which was probably the hardest decal i have tried to do and i thought i had cracked it till i saw that picture. also noticed that my pictures look rubbish on the computer.
            • flyjoe180
              • Jan 2012
              • 12400
              • Joe
              • Earth
              Great build Andrew, it looks very nice indeed. You sure have been a very busy chap!
                You have been busy Andrew... Another nicely model!
                • stona
                  • Jul 2008
                  • 9889
                  It is not at all surprising that you thought that Dave. It is actually very difficult to say when a G-6 becomes a G-14! In simple terms the G-14 was supposed to be a new standard version of the Bf 109 incorporating all the modifications introduced during G-6 production. I can safely say that it was not an entirely successful plan. Maybe an idea for an article there
                  It looks good BTW Andrew.
                  • flyjoe180
                    • Jan 2012
                    • 12400
                    • Joe
                    • Earth
                    With that taller fin etc I at first thought it may have been a G-10. I have no idea how you tell the difference between a very late G and a K. Be keen to see an article on this Steve if you get the time/inclination to do so.
                    • stona
                      • Jul 2008
                      • 9889
                      Most obvious differences.
                      1 Radio equipment hatch moved forward from section 5 to 4
                      2 DF loop moved rearwards from section 2 to 3.
                      Also external.
                      3 Deletion of circular master compass hatch at section 2
                      4 Fuel and MW 50 filling points moved forwards from section 3 to 2
                      Cockpit changed quite a bit but sometimes visible in photos is the absence of the battery cover on the rear cockpit wall which had appeared on earlier MW 50 equipped versions.
                      There are of course others, but those above are often visible in photos.
                      I would consider writing an article, or maybe a synopsis. I don't want to make it too difficult, it's possible to write a book!. Something like a quick reference, not necessarily an exhaustive analysis
                      • flyjoe180
                        • Jan 2012
                        • 12400
                        • Joe
                        • Earth
                        Thanks Steve. Maybe you should consider writing a book, you have a vast knowledge of the Luftwaffe.
                          Wow! That looks impressive. That colour scheme is gorgeous.
