Revell 1/32 He162-A2 'Salamander'
  • BarryW
    • Jul 2011
    • 6028
    #16
    very nice Vaughan, very unusual too....
    • flyjoe180
      • Jan 2012
      • 12421
      • Joe
      • Earth
      #17
      Lovely work Vaughan, I followed your build and was impressed at every step.
      • tr1ckey66
        • Mar 2009
        • 3592
        #18
        Outstanding finish! This is another kit I have in the stash and if it turns out like this I will be very happy.
        All the best
        P
          Awesome work, Vaughan.........well done!!!!
            Originally posted by \
            How about putting it on a concrete stand with a single armourer next to it? Very simple but a human element would give it another dimension. The concrete base needs nothing more than a joint between two concrete slabs and a tuft of grass so very simple but would really enhance the model.
            I will experiment of course, but what would you recommend for concrete in 1/72? Plaster perhaps, finished to scale-sized roughness?
            I have read that "wet and dry" at the correct grit size can look like tarmac.
            Really nice work Vaughan.
            • Alan 45
              • Nov 2012
              • 9833
              #21
              Great build you've done a fantastic job on the engine and at £15.99 that's a bargain I might keep an eye out for one of these
                A gorgeous build Vaughan, with some nice detailing.
                  I have used plaster for concrete and used wet and dry for racing track to display bikes on in the past. I would use a thin layer of plaster and scribe a line across it before it sets to create a joint. This will then take a wash nicely and make a realistic joint.
                  • Wendall
                    • Jun 2013
                    • 918
                    #24
                    Fantastic build and a bargain to boot. Can't ask for more than that!
                    Jason
                      Beautiful work, all i can say is wow.
                      Scott
                      • Vaughan
                        • Apr 2011
                        • 3174
                        #26
                        Thanks guys for all you comments,
                        Wonderland are selling it for £8, I think ,at the moment a real bargain.
                        • eddiesolo
                          • Jul 2013
                          • 11193
                          #27
                          I will experiment of course, but what would you recommend for concrete in 1/72? Plaster perhaps, finished to scale-sized roughness?I have read that "wet and dry" at the correct grit size can look like tarmac.
                          I have some 1x1 square dense foam squares I got form a craft shop, they are ideal as concrete slabs in 1/72, easy to cut, then you just prime and paint.
                          Si
