This was done as an try at masking something a little bit more complex than I usually do. I should have airbrushed the red and white as close up you can see the brush marks. The red in particular was very claggy and when thinned took days to dry. Naturally when I held it up on its little bit of stick and wire to take the photo's it fell off and the drop tanks came off and if you look closely one of the fins went off into the wild green yonder of the lawn. The two photo's with captions are of the real thing (obvious really). I found masking up the white ring very hard and had about a zillion goes and a lot of tape at it. I did find that although once masked I had then clear glossed over the masked edges the red seemed to leak through the tape as it appeared in little blotches in the centre of white parts.[ATTACH]74953.IPB[/ATTACH]
[ATTACH]74954.IPB[/ATTACH]
[ATTACH]74955.IPB[/ATTACH]
[ATTACH]74956.IPB[/ATTACH]
