This is RS Models 1/72 Avia Ba.122, a pre-war civilian aerobatic aircraft although a few were pressed into service at the outbreak of hostilities. It's a short-run kit so needed quite a bit of work.
Czech biplane
Tags: None
[ATTACH]114396.IPB[/ATTACH]
jaw droppingly beautiful..........and didnt realise it was so small til the last picAttached FilesPer Ardua
We'll ride the spiral to the end and may just go where no ones beenComment
Wow that's tiny! And the finish is incredible! Hats off to you - great job.
Edit: The more I look the more impressive... e.g. the rigging, the wood effect on that tiny prop, etc. Kudos...Comment
Thanks for the kind comments, guys, much appreciated.
Incidentally, have I posted this in the wrong place? It was supposed to go in the 'Completed Airplanes' section but doesn't appear in that list. Perhaps a mod with powers could move it please?Comment
Just - beautiful. I used to make a lot of biplanes myself in 1:72, but since returning to modelling have been sceptical of the results in this scale. This restores my faith in what can be achieved - though it probably requires a level of skill well beyond mine! The prop is a work of art, and I appreciated the lack of weathering given that the original was a display aircraft. How did you pick out the panels and control surfaces - a pin wash perhaps?Comment
That Mike is a thing of beauty. And at that size. Wow.
Great job.
I'll move this for you, along with that loverly Texan.
Ian MComment
