In another thread I described the instruction for this model as 'a rough guide to where most parts probably go'. That is the most complimentary description of them I can make. I gained more information from downloading the Eduard 1/48 scale kit instructions from their website and using them. If you build this kit take nothing for granted, get lots of references and test fit at every point planning two or three stages ahead. Do that and you will find you get an enjoyable build, in fact this was one of the most enjoyable I have had. The instructions were rubbish but the plastic really wanted to get built and was viceless. No fit issues except the underside of the engine cowls where some plastic card and filler did the trick and a small amount of filler was needed at the front of the wing root.
A couple of things though:
1/ When I build another I will get after-market p.e. seat belts, the kit p.e. ones were awful.
2/ The kit exhausts really do need replacing with the Quickboost resin. They really enhance the appearance.
3/ The decals are poor. Correction, they are incomplete, they went down well but there were no swastikas (as is so often the case) and no stencilling. I got an EagleCal set for these markings and the model really needs them simply because there are a lot of very colourful and prominent details that need adding, red no-walk lines, yellow and red warning triangles etc etc. the model looks all the better for them.
Anyway, take a look......
[ATTACH]76533.IPB[/ATTACH]
[ATTACH]76534.IPB[/ATTACH]
[ATTACH]76535.IPB[/ATTACH]
[ATTACH]76536.IPB[/ATTACH]
[ATTACH]76537.IPB[/ATTACH]
[ATTACH]76538.IPB[/ATTACH]
[ATTACH]76539.IPB[/ATTACH]
[ATTACH]76540.IPB[/ATTACH]
[ATTACH]76541.IPB[/ATTACH]
[ATTACH]76542.IPB[/ATTACH]
