Desert Mirage
  • The Migrant
    • Apr 2011
    • 1268
    Desert Mirage
    Another oldie, the Airfix 1/72 Mirage F.1, one of my all-time favorite jets (along with the Hunter and F-86). Quite a nice little kit from the 70s, I rescribed the panel lines, added some cockpit detail and hollowed out the jet pipe. Markings are homemade for a Qatari AF plane.
    Awesome build Mike, great paint job as well
    • yak face
      • Jun 2009
      • 13841
      • Tony
      Beautiful work Mike , how you re-scribe so neatly is beyond me , i cant do it to save my life !! cheers tony
        • 22770
        Great work Mike
        • Alan 45
          • Nov 2012
          • 9833
          Very nice love the paint job , did you know that in the seventies the desert was so hot that sidewinders couldn't lock on to aircraft and went straight into the ground
          • flyjoe180
            • Jan 2012
            • 12415
            • Joe
            • Earth
            Beautiful model Mike, another oldie which after your build rivals anything the new tool kits can produce.
              This is really good mate. The scribing looks nice and the paint is superb.
              • The Migrant
                • Apr 2011
                • 1268
                Thanks for the looks and the comments, much appreciated
                • colin m
                  • 8755
                  • Colin
                  • Stafford, UK
                  Very nice Mike. I think the re-scribing really makes the model stand out. It really doesn't look like a 70's kit now.
                    Paint job incredibly good.
                      Yep!! I miss this one O_o
                      Another impressive model Mike!
                      Polux
                        Mike: any tips on getting such a perfect finish? For example, acrylic, enamel? Do you lightly sand every coat including the primer? It's airbrushed, right?
                          Beautiful work indeed.
                          scott
                          • Vaughan
                            • Apr 2011
                            • 3174
                            Another outstanding build Mike.
                            • The Migrant
                              • Apr 2011
                              • 1268
                              Thanks for the comments, guys.
                              Cheers Steve. I usually prime my models with Tamiya white fine surface primer, decanted from the rattle-can and airbrushed. The camo colors are Tamiya acrylics, thinned with Tamiya's own lacquer thinners and airbrushed, no sanding between coats. IIRC the underside blue is Xtracrylix. I used paper masks to get the semi-soft demarcation lines. A couple of coats of Future, decals applied, then airbrushed with Testors Flat.
