FINISHED F-14B 'Red Ripper' Tomcat - 1/32 Trumpeter
    Well here it is for better or worse, an OOB build except for the Aircrew. A disappointing kit, poor fit in may places, poor assembly and very poor painting instructions. You will notice the front of the canopy is a poor fit, it is wider than the body, if you trim it you loose the rivet detail on the canopy. You have to guess where some of the decals go, no Nose wheel landing lights, wrong shape of missile carriers etc. etc.
    Anyway here it is, hope you enjoy, comments welcome. Apologies for the background.
    Cheers Derek
    [ATTACH]79625.IPB[/ATTACH]
    [ATTACH]79626.IPB[/ATTACH]
    [ATTACH]79627.IPB[/ATTACH]
    [ATTACH]79628.IPB[/ATTACH]
    [ATTACH]79629.IPB[/ATTACH]
    [ATTACH]79630.IPB[/ATTACH]
    [ATTACH]79631.IPB[/ATTACH]
    [ATTACH]79632.IPB[/ATTACH]
    [ATTACH]79633.IPB[/ATTACH]
    [ATTACH]79634.IPB[/ATTACH]
    [ATTACH]79635.IPB[/ATTACH]
    [ATTACH]79636.IPB[/ATTACH]
    [ATTACH]79637.IPB[/ATTACH]
    [ATTACH]79638.IPB[/ATTACH]
    [ATTACH]79639.IPB[/ATTACH]
    • 22771
    Derek even with all the problems with this kit it's a great build, and mostly down to your skill. A stunning looking Tomcat, and the bin shows the true size of it. Well done again
      • 18271
      As the other Ian said. That looks great regardless of the issues you had along the way.
      The paint is fantastic and it looks most impressive!
      Great work Derek
        It's a shame such a big, expensive kit should be so lacking, but you've turned
        it into a smashing build Derek.
        The look of the big 'cat is just right for sitting on the flight line, ready to be blasted into the blue!
        Top job!
        Patrick
        • geegad
          • Mar 2010
          • 2329
          as said even with all the problems you've knocked it out the park with your build and weathering it looks superb''and all the problems cant be seen because of the look of the hole thing i would display this with pride..just show how good a modeller you are for all the faults you can produce such cracking build
          • Dave W
            • Jan 2011
            • 4713
            That's a very impressive model.Shows great attention to detail.
              Thanks very much for you kind comments Gents. As you can gather from my comments an expensive disappointing kit. Cheers Derek
              • flyjoe180
                • Jan 2012
                • 12429
                • Joe
                • Earth
                A beautifully made Tomcat Derek, great build. You have done a fabulous job on the weathering and panel lines, and despite the kit issues your work has turned out a fantastic model. Also it is refreshing and nice to see a colourful F-14 in markings that aren't, as you said, the usual 'skull and cross bones' or rising sun markings.
                  Bad kit or not, that looks amazing!
                  Sent from my C6903 using Tapatalk
                  • yak face
                    • Jun 2009
                    • 13842
                    • Tony
                    Superb work Derek, despite the faults youve turned it into a fantastic looking model . Excellent paint skills as per your usual standards , great build mate , cheers tony
                      Joe/Gav/Tony, Many thanks for your kind comments, much appreciated. Cheers Derek
                      • The Migrant
                        • Apr 2011
                        • 1268
                        Superb Derek, I can only echo what the others have said. A really excellent finish; how did you achieve the subtle mottling of the base grey?
                          Thanks Mike, If you look at my reply to Ole in my under construction entry top of page 5 ( http://www.scale-models.co.uk/threads/f-14b-tomcat-1-32-trumpeter.18941/page-5 ) you will see how I weathered the Tomcat. For the mottling around the panel toggle fasteners I used very dilute white paint and applied a small amount with a fine brush, just as it dried I rubbed it with a cotton bud. Cheers Derek
                          [ATTACH]79682.IPB[/ATTACH]
                          [ATTACH]79683.IPB[/ATTACH]
                            Derek that is a truly outstanding looking Tomcat! I keep looking at the pics and seeing new details pop out every time. 5 star build for sure,very nicely done Sir!!!
                              Thank you Trey, from you that's a real compliment. Cheers Derek
