Jim R's 1/72 Airfix de Havilland Vampire T.11 (Starter Set GB)
    • 15817
    Hi all
    Completed this lovely little kit. Shown as a plane from No14 Squadron, Royal New Zealand Air Force.
    I am going to build this kit again, without any restrictions, as the second part of this GB. It won't be straight away but I'll post pictures here when it is complete and a comparison can be made.
  • stillp
    • 8106
    • Pete
    • Rugby
    That looks great Jim, especially considering you used the kit paint. Just shows what can be done! Looking forward to seeing what you can do without the GB restrictions.
      Very nicely finished Jim considering what you had to use :smiling3:.
      • Neil Merryweather
        • Dec 2018
        • 5208
        • London
        Sir, Sir!
        Jim cheated , he used an airbrush for the silver ,sir!
        • Neil Merryweather
          • Dec 2018
          • 5208
          • London
          Jim that looks brilliant for no 11-how did you do it?
            • 15817
            Hi Neil
            I mixed no 11 with no 56 (another metallic in the set) - ratio 2:1. Diluted it a lot and added a drop of washing up liquid. Working quickly I painted one area at a time. What you see is 6 or 7 coats. The grey plastic helped.
            • Neil Merryweather
              • Dec 2018
              • 5208
              • London
              washing up liquid eh?
              I'll have to remember that
                • 15817
                The washing up liquid helps the very watery paint to spread evenly over the surface. It reduces surface tension so the paint doesn't bead up so much. I saw the idea on YouTube somewhere.
                • stillp
                  • 8106
                  • Pete
                  • Rugby
                  I thought of trying that when I found I couldn't thin the paint as much as I'd wanted, wish I had now having seen your results.
                  • peterairfix
                    • Jul 2012
                    • 11088
                    That's a great result I can't believe it's brush painted.
                    • Steve Jones
                      • 6615
                      Well done Jim. I have watched from afar but enjoyed your tenacity to get this starter kit looking as good as it does. Good luck with round 2
                      • scottie3158
                        • 14253
                        • Holbeach
                        Jim,
                        That is a great result
                          • 15817
                          Thanks guys
                          I'm looking forward to round 2. I have ordered a kit, an Eduard pe set and some canopy masks.
                            • 22788
                            Great work Jim.
                            • colin m
                              • 8806
                              • Colin
                              • Stafford, UK
                              Great result. Brush painted - wow.
