Mosquito PR Mk34 Conversion from Airfix PR XVI 1/48.(Rons Recon GB).
    • 18271
    Well I can't find anything else to add/do to this so I think I will quite while I'm ahead!
    As per the Build thread: https://www.scale-models.co.uk/threa...ix-1-48.33679/
    This was beaten together from the Airfix kit of the Mk XVI. 99% of the differences are avionics and a few minor details to the air-frame.
    I could have added the correct shape underwing tanks, but at £25 I thought it a bit over the top, the base kit having cost just over a tenner...!
    I enjoyed the build and have now found that if I save up from my pocket money (lol) I can get the resin parts needed to convert the much nicer Tamiya kit. (also in both 1/48 and 1/32 I believe). Not that this is not a nice kit..... Once built.
    My biggest moan would have to be the very weak main wing fitting points. Its just a bit hit and miss. On this particular build mostly miss!
    Thank God for Milliput.
    Painted with Xtracrylix paints and the tiny amount of weathering done with Vallejo washes: brown black and grey. Yes I applied the exhaust stains with a brush! Idea was to make it looked stained but also washed/cleaned. Its a post war kite and they had more than enough time between sorties to get the soapy water and brooms out!
    As a point of interest, maybe to some, This flew out of Singapore and was the last Mossie flown on active duties for the RAF.
    Hope you like her. I do.
    Sorry if the photos are a bit washed out.
    Comments welcome.
    • 22771
    Very nice work indeed Ian a great job on an old kit.
    • colin m
      • 8770
      • Colin
      • Stafford, UK
      Great job. I don't think I've seen a photo reconnaissance Mosquito before.
      • yak face
        • Jun 2009
        • 13855
        • Tony
        Fantastic job Ian , the build wasnt exactly a walk in the park but youve nailed it , loving the scheme , cheers tony
        • Mickc1440
          • 4779
          Great finish Ian
          • flyjoe180
            • Jan 2012
            • 12433
            • Joe
            • Earth
            Great result Ian. Glad the landing gear took the load okay given the difficulty with it.
              Hi Ian terrific job, nice to see in these colours makes a nice change, like the fact at the end very interesting made me look into it a bit more :thumb2: .
              Pete.
              • adt70hk
                • Sep 2019
                • 10433
                Ian
                I like her very much. Very nicely done indeed and as the others have said something a bit different!!
                ATB
                  • 15746
                  Hi Ian
                  Something different. A great result from a difficult kit. Perhaps more satisfying because the kit had its problems which you had to overcome. Well done.
                    • 18271
                    Thanks Chaps. It must be the masochist in me. Its nice with an easy kit but the challenge of an 'iffy' one does have great rewards. Nothing worse though than fighting a build all the way only to find that the last parts, normally a wing or canopy just will not fit what ever you try. (That reminds me..... Gannet canopies still need finding!)
                    Cheers!
