Ian M's Mosquito Mk VI ,Tamiya 1/48 (Papa 695's Mossie GB).
    • 18272
    Well not a lot to say about the kit. It was a Tamiya. The fit was great, the destructions clear, and the decals thick. so just what you expect. The kit almost builds itself.
    Here is My version of SZ977 of 21 squadron. HT - Y Lost during a bombing raid over Copenhagen.
    The aircraft hit a light pole with a wing tip which sent it out of control and crashing into a local school. The resulting smoke and fire confused some of the following aircraft into thinking the school was their target, thus dropping their bombs onto the school.
    Fortunately the error was seen and the remaining bombers diverted their attention to the correct target. Shell House.
    Painted with Xtracrylix acrylic paints over Stynylrez primer. (dont you just love some of the name paints have these days!)?
    Undercarriages painted with Alclad white Aluminium.
    Totally OOB with the exception of the pilot tube on the tail which is scratched from brass tube...
    The build thread is here if you missed it: https://www.scale-models.co.uk/threa...a.39672/page-4
ID:	1181624Click image for larger version
ID:	1181625Click image for larger version
ID:	1181626Click image for larger version
ID:	1181627Click image for larger version
ID:	1181628Click image for larger version
ID:	1181629Click image for larger version
ID:	1181630Click image for larger version
ID:	1181631Click image for larger version
    Hope you like her.
    Comments and suggestions welcome.
    If I go back to it to seal things down, I'll post a couple of pictures up in here...dont hold your breath though. lol
    Thanks to Ian (papa695) for getting the GB off the ground.
    Right I'm off to see if I can find an Airbrush.
    • 15816
    Very nice indeed Ian. You look to have got the Tamiya decals to behave. The story behind the plane is fascinating but rather frightening as well.
    • Mark1
      • Apr 2021
      • 4156
      Certainly looks the part, lovely job.
      • Flip
        • Jul 2022
        • 259
        • John
        • Speyside
        Ian,
        Are you building all of these at the same time? (Mossie, Spitfire etc.) In ordinary parlance, that is called a production line :smiling2:
        Lovely build
        Kind regards,
        • Allen Dewire
          • 4741
          • Allen
          • Bamberg
          Afternoon Ian,
          A very fine job you've accomplished here Sir!!! Nothing wonky that I see at all. Just an overall nicely done Mossie. I can only hope that mine will be half as good as yours when it's done. I take it you only used 2 colors on the camo scheme, BS 637 and BS 241, or did you use 3???
          Allen
          PS, have you decided on which new hissy stick yet???
          • Airborne01
            • Mar 2021
            • 4038
            • Steve
            • Essex
            Now I'm scared - my mossie had better come out half as well - or else!
            • adt70hk
              • Sep 2019
              • 10439
              Ian,
              That's turned out beautifully. A reall top notch finish.
              Very well done indeed.
              ATB.
              • The Smythe Meister
                • Jan 2019
                • 6248
                [ATTACH=CONFIG]n1181624[/ATTACH][ATTACH=CONFIG]n1181625[/ATTACH][ATTACH=CONFIG]n1181626[/ATTACH][ATTACH=CONFIG]n1181627[/ATTACH][ATTACH=CONFIG]n1181628[/ATTACH][ATTACH=CONFIG]n1181629[/ATTACH][ATTACH=CONFIG]n1181630[/ATTACH][ATTACH=CONFIG]n1181631[/ATTACH][ATTACH=CONFIG]n1181632[/ATTACH]
                Hope you like her.
                Excellent stuff Ian!
                I`m loving that.... a LOT:hugging-face:.....
                As an aside,if you don`t mind me asking,did you use an acrylic black wash for the panel details..... or something else?
                Hope mine comes out half as good..... when i finally get round to STARTING it that is!!
                  • 18272
                  Afternoon Ian,
                  Allen
                  Used the two on the top side and a 3rd on the belly if that is what you ment. Sea grey I think...hang on...
                  Here you go. Medium sea grey for the underside, dark green and camouflage grey for the top. (probably should be Dark sea grey).
                  Maybe not 100% the correct grey for the top but close enough.
                  Hissy stick of the moment is a H&S Infinity CR plus (maybe the 2i1).
                    • 18272
                    I am sure it will Steve.
                      • 18272
                      Originally posted by adt70hk
                      Ian,
                      ATB.
                      Thank you Andrew. Means a lot.
                        • 18272
                        Thank you Andy.
                        I did titivate it a bit with some Vallejo Panel wash. Streaked it out with a dry brush to get the wind blown look.
                        I am sure that you too will do a great job.
                          • 18272
                          Originally posted by Flip
                          Ian,
                          Lovely build
                          Kind regards,
                          Nope built the spitfire first, then went into this one. Already started on the next victim.
                            • Jan 2019
                            • 6248
                            Ah,I see, Thanks for that :thumb2: ,
                            • langy71
                              • 1957
                              • Chris
                              • Nottingham
                              Nice build Ian, this has turned out beautifully,
                              A real tribute to the original aircraft and the sad story behind her. The pictures really show her off brilliantly.
