Italeri AH64D Longbow
  • Lee W
    • Feb 2014
    • 4654
    • Lee
    • Sherborne
    Hey guys and gals,
    Something out of my league, OOB, filling here and there, I threw it together the best I could, as much as I like the Apache, this one I hated! Simplicity of parts, bad fit and bad temper!!!
    I wouldn't build another from Italeri !
    [ATTACH]84591.IPB[/ATTACH]
    [ATTACH]84592.IPB[/ATTACH]
    [ATTACH]84593.IPB[/ATTACH]
    [ATTACH]84594.IPB[/ATTACH]
    Please be gentle...Waiting for the usual
    Lee
    • 22770
    I like that very much Lee I did a 1/72 one not long ago and know what difficulties you have
    • eddiesolo
      • Jul 2013
      • 11193
      Looks okay to me Lee, have seen a lot worse...normally on my bench lol. Like it mate.
      Si
      • monica
        • Oct 2013
        • 15169
        looks good to me Lee and ever you had trouble with it dose not show, well done,
        • flyjoe180
          • Jan 2012
          • 12390
          • Joe
          • Earth
          It looks okay to me Lee. You're just grumpy with yourself. One thing though, your decals could benefit from being applied over a gloss coat. That will prevent that silvering which is apparent in some of your photos. Surprised at your experience though, I've generally found Italeri aircraft to be nice to build. BTW the Airfix and Italeri Apache Longbows are from the same moulds.
            It looks good to me Lee, I certainly wouldn't mind that on my shelf.
            • Alan 45
              • Nov 2012
              • 9833
              With the problems you faced lee I'd say you made a great build mate there's nothing wrong there it looks good if you want a good longbow try revells 1/48 it's a nice kit with no filling required even I did a good job with it lol
                Looks good to me mate. Nicely done
                  Well done, looks fine to me
                  • Lee W
                    • Feb 2014
                    • 4654
                    • Lee
                    • Sherborne
                    Thanks for you comments people.
                    Now, as Joe pointed out, the decals are silvering (I hadn't noticed ops.
                    Yes it's time for...stupidly thick question time (yay applaudo_O), I understand that decals have a coat of gloss but my stupidly thick question is, I'm using a hairy stick, what's the process of decal application? In my defence, that's the most decals I've put on a model in a very long time, I suppose it's lack of experience ops:
                    Thanks in advance
                    Lee
                      Can't comment on the decals but the model looks fine to me I wouldn't mind it on my bench.
                      • flyjoe180
                        • Jan 2012
                        • 12390
                        • Joe
                        • Earth
                        Same process Lee. Brush paint, then apply a gloss varnish. Humbrol's Gloss Cote can be brushed on, or you can get it in an aerosol, or you can airbrush the stuff. It's all on their website with tutorial videos (which I refer to all the time). Once dry apply your decals; I use Humbrol Decalfix to help the decals settle into the crannies, then once all that has dried, you can flatten (matt) the finish with a matt varnish, same process as the gloss. Humbrol stuff is called Matt Cote. Lots of other options. That's it in a nutshell. Don't be hard on yourself about the decals, it's a minor point that would only improve the appearance of you otherwise finely painted model.
                        • Lee W
                          • Feb 2014
                          • 4654
                          • Lee
                          • Sherborne
                          Ok, thanks for that Joe...advice always greatly appreciated.
                          When doing armour, any decals can be smothered in dirt or they're hidden...no problems.
                          Thanks again Joe
                          Lee
                          • flyjoe180
                            • Jan 2012
                            • 12390
                            • Joe
                            • Earth
                            No problem Lee. I'll seek you out for advice if I ever get around to doing a tin can
                            • Lee W
                              • Feb 2014
                              • 4654
                              • Lee
                              • Sherborne
                              That's not a problem Joe...thinking about it, I'm crap with advice, so it could be a problem...
                              Here's the next on the table, hand picked from the stash by my lovely SWMBO Lisa...
                              [ATTACH]84643.IPB[/ATTACH]
                              This should be fun o_O
                              Lee
