TF141 CH-46D Seaknight, Done. It's a HobbyBoss kit.
Gunze 308 for fuselage and Gaia Pure Black for propellers & black areas on the fuselage. I use both Hobbyboss stock decals and self-printed decals.
Smoke stain by using soft pastel after semi-flat top coat.
The instruction sheet stated that this helicopter color should be in 339 Engine Grey so they provided the water decals which mostly in white color. White decal on Gunze308 basically you see nothing on it. So i came out with my own design and print it.
The theme is based on Call of Duty: Modern Warfare 2 I personally love TF141 so much, so I make this Seaknight into a TF141's Seaknight.
Weathering, washing & filtering done with Tamiya enamel paint and oil paint, I use dark brown and black soft pastels to create the smoke stain effect on the tail.
For diorama, actually the plan is make CH-46D and Mil Mi-28 together in a scene which the Mi-28 is also TF141 themed but due to the size problem, so I may need to plan again.
W.I.P. here
[ATTACH]124111.IPB[/ATTACH]
[ATTACH]124112.IPB[/ATTACH]
[ATTACH]124113.IPB[/ATTACH]
[ATTACH]124114.IPB[/ATTACH]
[ATTACH]124115.IPB[/ATTACH]
[ATTACH]124116.IPB[/ATTACH]
[ATTACH]124117.IPB[/ATTACH]
[ATTACH]124118.IPB[/ATTACH]
[ATTACH]124119.IPB[/ATTACH]
[ATTACH]124120.IPB[/ATTACH]
[ATTACH]124121.IPB[/ATTACH]
[ATTACH]124122.IPB[/ATTACH]
[ATTACH]124123.IPB[/ATTACH]
[ATTACH]124124.IPB[/ATTACH]
[ATTACH]124125.IPB[/ATTACH]
Thank you so viewing, have a great day!
Cheers!
W.I.P. here
Cheers!
