SeaKIng Finished Joins Falkland Conflict Dior[ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]ama
1/48 Hasegawa SeaKing HC4 Royal Navy Conversion
GuestTags: None
HI Laurie what Richard said above an I think it looks real I shall do some on my tiger seaking s in this coulor an may I as a question please how come your main undercarts have not got those ugly float on them ? as I would like to build mine like yours as I cant stand them floats as I have never noticed them on or off
chrisComment
LaurieComment
Thanks Ian much appreciated.
Comes with all the Jersey decals.
chris
The conversion set was obtained from David Parkin's Flightpath. This contained metal castings, resin sponsons (your floats)
& about 4 frets of PE. The PE is double thickness of Eduard & you build parts not just stick them on. Very intricate & enjoyable.
A lot lot of folding. The staircase is made up of about 14 parts of PE
Thanks to you all
LaurieComment
