How do I build missing Kit pieces?
    Hey all! I'm relatively new to building and painting models and have been working on a 1:48 BF 109 F... painted JG 26 as it will be a very late Battle of Britain Aircraft... Dont worry my next plane is a Battle of Britain Spitfire Mk II!
    Somewhere along the line I lost the two wheels from the kit. The landing gear is still there but not the tires.
    I have racked my brain trying to figure out how to go about getting replacements. In fact the model is all but complete except for the tires. I dont want to order new pieces and dont have the artistic ability to do a whole lot... Any suggestions as to what I could do to replace them? Thanks guys.
    Theres no simple answer to this unless you're a skilled styrene carver.
    The easiest way would be to get another kit then do one wheels up, does the kit have a wheels retracted option, could you maybe use the 'typically' half wheels?
    I would offer to look through the bits box but I know I don't have any wheels in 48th scale, possibly some in 72nd.
    Another option would be if you could borrow a wheel then make a quick simple resin cast using halfords resin and some alginate from a craft store, but by the time you've bought those another kit may be as cheap?
    • stona
      • Jul 2008
      • 9889
      I think you'll have to cast some or buy some new ones. The Bf109F doesn't have fully enclose wheel wells so even "wheels up" you'll still need to have them.
      • wonwinglo
        • Apr 2004
        • 5410
        Go to a florist and purchase a block of oasis,if you have one wheel to use as a pattern simply press this into the oasis to make the impression half way,next mix up some car auto filler ie P38 and lay in with a pallette knife skimming the surface so you have moulded one half of the wheel,repeat for the other side,smooth in some more P38 to join together and trim up with a small file,you can reproduce many lost parts this way and once painted you can hardly tell,give it a try and practise a little for excellent results.
        Wonwinglo.
