CAC Boomerang
    CAC Boomerang
    Hi i am looking for a CAC Boomerang kit (aus fighter ww2)
    i do not no if it is available.
    Yes there are a few out of production plastic kits available in 1/48 LTD made a limited run kit that I built not too long ago and there is a 1/32 Resin kit made by Alley Cat usually quite expensive when you can find this one. There may be others as well,hope that helps and welcome to the forums.
    • yak face
      • Jun 2009
      • 13829
      • Tony
      Hi Yogo , welcome to the forum. The boomer is a great aircraft isnt it , as far as I'm aware there havent been too many kits but apart from the ones mentioned by Trey above I can add these - Special Hobby do a 1/72 kit and a 1/48 kit , and theres the old faithful Airfix in 1/72 . The Special Hobby kits are still in production but the airfix kit isnt but can still be found readily on E-bay and other such places . If youre not fussy about interior detail , the Airfix kit makes into a great little model , but if you want a bit more than a pilot on a slab seat then the special hobby kits are the way to go! Hope this helps ,cheers tony . P.S. if you want to see a couple of builds , use the search bar at the top , searching CAC Boomerang should bring up Treys 1/48 LTD build and my 1/72 Airfix one .
      • flyjoe180
        • Jan 2012
        • 12381
        • Joe
        • Earth
        I built the 1/72 Airfix Boomerang too and it turned out a nice little model. I think I drilled the extra gun ports into the wings but apart from that it was standard out of the box stuff.
        Here is Trey's 1/48 LTD Boomerang: http://www.scale-models.co.uk/community/threads/ca-13-boomerang-1-48-ltd-completed.16189/
        Tony's 1/72 Airfix: http://www.scale-models.co.uk/community/threads/airfix-1-72-cac-boomerang-completed.16740/
        My 1/72 Airfix: http://www.scale-models.co.uk/community/threads/airfix-1-72-cac-13-boomerang.17992/#post-154673
          thank you
          I got 1 now
          • yak face
            • Jun 2009
            • 13829
            • Tony
            Originally posted by \
            I built the 1/72 Airfix Boomerang too and it turned out a nice little model. I think I drilled the extra gun ports into the wings but apart from that it was standard out of the box stuff.Here is Trey's 1/48 LTD Boomerang: http://www.scale-models.co.uk/community/threads/ca-13-boomerang-1-48-ltd-completed.16189/
            Joe ,please accept my grovelling apologies , i completely forgot your build!! my memories not what it used to be , cheers ...er whats my name now ,.. ah Tony
            • flyjoe180
              • Jan 2012
              • 12381
              • Joe
              • Earth
              Ha, no worries Tony. I have a touch of the old memory loss too. Cheers
