Luftwaffe color help needed please
    I'm getting ready to start a He 162 and finding some confusing color call outs for the interior, would RLM 02 be correct or RLM66 ?
    Some googling shows it to be grey, so I recon66 will be OK.
    Theuns
      thanks Theuns
      • Alan 45
        • Nov 2012
        • 9833
        I don't think the Germans had a standard grey for the interior so either of those would be ok
          Not true at all. I can only speak for fighters but cockpit interior was standardized as RLM 02 (except for the instrument panel which was 66) early in the war, and from '41 onwards it was all 66.
          Don't know how it was for attackers and bombers, but the RLM had a habit of regulating everything very thoroughly! I'd do some research nefore painting...
          Sent from my SM-N9005 using Tapatalk
          • Alan 45
            • Nov 2012
            • 9833
            Not true at all. I can only speak for fighters but cockpit interior was standardized as RLM 02 (except for the instrument panel which was 66) early in the war, and from '41 onwards it was all 66.Don't know how it was for attackers and bombers, but the RLM had a habit of regulating everything very thoroughly! I'd do some research nefore painting...
            I'm not doubting your correct but I've seen different shads of grey in actual aircraft but that could be just how it's been renovated so you are probably right
              As I understood it the RLM02 was superceded later by 66 ,so as the 162 was later it would seem logical that 66 would be correct? Of course as supplies of materials were getting stretched thin late in the war would 02 have been used just because it was on hand?
                As long as it was not 50 shades of grey...
                Theuns
                • Alan 45
                  • Nov 2012
                  • 9833
                  As long as it was not 50 shades of grey...Theuns
                  I dunno but goreing isn't around to ask
                    My 162 cockpit is painted in 66 Trey! Not that anyone's seen it yet ...
                    • stona
                      • Jul 2008
                      • 9889
                      RLM 66 cockpit.
                      RLM 02 was still in use and may have been present in other interior areas, but not the cockpit.
                      • stona
                        • Jul 2008
                        • 9889
                        You are essentially correct about fighters, though a dark colour, presumably RLM 66 was appearing in late 1940, particularly seen in updated or refurbished Bf 109s. Many of the heavier, squared off, canopies being fitted to the E-4/7 standard had RLM 66 framing inside and out. Instrument panels came in several greys early on, but I'd have to check to say which and I can't do that from Glasgow Green
                        Both Heinkel and Junkers were using RLM 66 in visible interiors (think of all that glass) by 1939/40. This makes the Ju 87 a bit tricky, though early ones seem to have kept RLM 02 after their larger brethren had started to adopt RLM 66.
                        The only thing you can be certain about is that nothing is certain.
                          Thanks for all the input Fellas. Steve so 66 thru out the landing & gun bays would be correct?
                          • stona
                            • Jul 2008
                            • 9889
                            If the landing and gun bays were painted I think that they'd be in RLM 02.
                            I can't look anything up at the moment (home tomorrow) but it must be possible that the gun bays in particular were not painted at all, just going by other late war designs. Saving both time and resources had become an important factor.
                              These are pictures of a restored He-162, the cannon bay & cockpit
                              [ATTACH]88726.IPB[/ATTACH]
                              [ATTACH]88727.IPB[/ATTACH]
                              The website is
                              http://memorial.flight.free.fr/He162uk.html
