Searching a "special item"...
    Hi guys!
    This is a master calling
    Someone knows if there is a plane, 1/32, like the Hawker Typhoon 1/24...? I need to see the engine and some inner parts of the wings.
    Thanks
  • PaulTRose
    • Jun 2013
    • 6460
    • Tattooine
    you mean like a hurricane or spitfire?...........theres loads out there, especially by Revell, in 1/32
    Per Ardua
      Hi Polux
      Are these what you are after
      Try this also http://www.largescaleplanes.com/articles/
        • 18266
        Do you mean that are built up in the same way...?
        Or do you mean a 1/32 Typhoon...
          Sorry guys, I will explain it better :P
          I'm searching for a 1/32 plane. All eras and nationalities...
          I was thinking to build the Typhoon (1/24) as a wrecked model, but maybe the base will be so big....O_o
          I will join in with a 1/32!!! But I need a interior detailed model
            • 18266
            Sit down take a deep breath and think of all of us that have just feinted in shock.....!
            As for 1/32 scale aircraft with loads of detail... http://www.zoukeimura.co.jp/en/products/index.html
            not cheap but maybe what you are after...Personally if I was building a wreck I would go for the cheapest I could get and just scratch the detail that will need to be shown.
            • stona
              • Jul 2008
              • 9889
              The best interior detail I've seen on any kit that I have built recently was the 1/32 Ta 152 by Zoukei Mura. The Trumpeter kits also have good internal detail, I'd recommend the Me 262.
              Likewise the Eduard kits are pretty well detailed internally.
              For a 'wrecked' scenario I think you will always have to scratch build some of the internal structure, frames, ribs, stringers etc. but at least the kit should provide fuel tanks, radios, air/oxygen bottles, armament and the like.
              I don't know what you have in mind but weapons and ammunition were always the first things removed when an aircraft fell into the hands of the enemy military. Civilian looters always went for instruments, particularly clocks, and the obvious souvenirs like parachutes (if they were still there) swastikas, victory markings etc.
              It sounds like a very interesting project and I expect that you will manage something pretty spectacular
