Spitfire Elliptical Wings
  • HAWKERHUNTER
    • Feb 2012
    • 1489
    • Steve
    • Halifax, West Yorks.
    Did anyone else see the documentary on the Spitfire broadcast earlier this year. In it they revealled that RJ Mitchell had a big design team around him during the development of the Spitfire and that one of his team, Beverley Shenstone, a brilliant areodynamasist, had been working for the German company Junkers in the late 20's where one of the german designers had come up with the idea of the elliptical wing. Beverley Shenstone then brought the idea across to Supermarine where it was developed for the Spitfire. So our beloved national icon the "Spitfire" has a german designed wing. I never knew that.
    Click image for larger version  Name:	sp.jpg Views:	8 Size:	700.9 KB ID:	1235881
  • Geoffers
    • Jan 2017
    • 1655
    • Geoff
    Or a British designed wing based on a German idea ?
    I believe the Heinkel He 112 had an elliptical wing but was found not to be as good an aircraft as the Bf-109 so that was the one the Luftwaffe chose.
    Otherwise the BofB might have seen an elliptical wing fighter on each side.
    Geoff.
      • 18871
      Ever seen the designs he came up with for an elliptical winged heavy bomber? Looks quite strange, like a cross kitted job using a 1/32 spitfire and a 1/72 Lancaster….
        • 18871
        Lots on it here….
        Germany’s greatest fighter What if the Spitfire – that most iconic British fighter – wasn’t? British, I mean. What if it’s sighed-over elliptical wing (which, as any attentive high school student c…
        ….and here’s the bomber….
        • langy71
          • 1947
          • Chris
          • Nottingham
          Looking at the picture Tim, you've gotta admit Mitchell's team did it better..
          • HAWKERHUNTER
            • Feb 2012
            • 1489
            • Steve
            The early design drawings that I saw in the documentary that were produced by the Junkers design engineers when viewed from above appeared almost indenticle to the wing of the Spitfire although I am sure there was a lot more work done by Shenstone to end up with the wing that we are so familiar with today. I think the idea of the elliptical wing was primarily the brain child of Ludwig Prandtl .
            • A_J_Rimmer
              • May 2024
              • 800
              • Arnold
              • North Wales
              The other thing that a lot of the British fighters carried early on in the war and in the B of B was a German built Gunsight - the last batch, IIRC, was delivered after war was declared.
              Arnold Judas Rimmer BSc SSc
              ''Happiness is a Triple Fried Egg Sandwich with Chilli Sauce and Chutney''
              • stona
                • Jul 2008
                • 9889
                'Elliptical' wings had well known arodynamic advantages, beyond the scope of a brief answer. It was a planform that featured on many aircraft of the period. The P-47 used such a wing as did several other airframes, notably in Russia. It was also seen on Seversky and Dewoitine monoplanes in France. It had been seen on British and Italian aircraft before 1930. The properties of ellipsoidal wings had been studied by Prandtl, Kutta and Lanchester, among others. Elliptically shaped wings had been drawn and modelled by Joukowsky C.1900 and Junkers (Hugo) in 1910. In France, Alphonse Penaud had built an elliptical flying wing in 1870!
                The Spitfire wing has very complicated geometry. It is composed of two differing elliptical sections of equal span, with differing root chords. It is a deliberately distorted or swept forwards ellipse. The forward sweep enhanced th elliptical flow patterns and span loadings, minimising the deleterious drag effects of the twist (washout) designed into the wing. It was informed by the glider design and delta wing studies that Shenstone had done, in Germany, with Alexander Lippisch.
                It was not really like any other ellipsoidal wing and as Shenstone himself pointed out, quite different even in planform to that of the He 70.
                So what influence did the He 70 have? It had no influence on the Spitfire wing. Shenstone had designed an elliptical wing (for a flying boat) in 1929, it was not a new or unique idea then and certainly not in 1933/4 as the Spitfire concept developed. Rolls-Royce acquired an He 70 as an engine test bed and some have argued that Supermarine were influenced by this, even wind tunnel testing it (impossible in the UK at the time). The problem is that in November 1935, when the first Spitfire wing had been completed in metal, the prototype being completed a few months later, the Rolls-Royce He 70 was in bits, awaiting its engines, in Rostock, Germany.
                Shenstone had seen the He 70 at the 1933 (not 1934 as often reported) Paris Air Show. He was impressed, though not by the wing which would have been entirely unsuitable for a high performance monoplane fighter. He was very impressed with the smoothness of the skin, though he noted that it was achieved by layers of filling and paint which added significant weight. I'll leave the final word to Shenstone himself.
                "The ellipse was well known and had been seen before on other aircraft before Heinkel used it.
                Our wing was much thinner than that of the Heinkel and had quite a different section. In any case, it would have been asking for trouble to have copied a wing shape from an aircraft designed for an entirely different purpose."
                And.
                "...the He 70's shape only faintly resembles that of the Spitfire."
                On smoothness.
                "The Heinkel 70 did have an influence on the Spitfire, but in a rather different way, I was impressed by the smoothness of its skin."
