R\c gliders
    R\c gliders
    Hello all, I have built two gliders and now would like to try flying. I am looking for radio and am wondering if 2 channel car radio would be suitable?
  • eddiesolo
    • Jul 2013
    • 11193
    Hello Robin.
    Does it have a combination of ailerons, elevator, rudder and flaps?
    To be honest I think you really need a minimum of a three channel. For sailplane/gliders you don't really need a super fancy expensive transmitter but one that is suited for flying.
    Si
      I haven,t built kit y
      Originally posted by \
      Hello Robin.
      Si
      I have not got the kit yet but was hoping that elevator and rudder control would do?
      • eddiesolo
        • Jul 2013
        • 11193
        One of the best for stating out is a Joysway Hunstman 1100 with a 12v brushless motor and all the trimmings, comes with a 4 channel transmitter IIRC, all charges battery etc...price is a round ยฃ130 ish.
        You can do it on a 2 channel, best thing to do is have a play and see if it works okay.
        • eddiesolo
          • Jul 2013
          • 11193
          Try this site for more info: http://www.flyingsites.co.uk/newcomers/intros/gliders.htm
              Thanks for the help Eddie!
              • BBdave
                • Aug 2014
                • 825
                Elevator and rudder is fine for a glider so a 2 channel is fine if you can find a 2.4 ghz set that will save any mix up with other model users radio can be got for about ยฃ30 try giant cod or hobby king UK. the parkzone radian is a good starters motor glider and i might know someone with one for sale.
                    Very helpful Dave.. Thanks
                    • ojays
                      • Oct 2011
                      • 1713
                      I have used Planet T5 or 6 2.4Ghz for several years, which can be bought for around ยฃ45 in the UK.
                      Never had any problems myself, but be aware they do have a limited range.
                      Gregg
                      • Richi72
                        • Sep 2013
                        • 1100
                        Hi, to be honest, it is possible with a 2 channel but, if you can't start your glider to a suitable height you gone need a motor and then you already have a problem because you can't control anything else.
                        Depending on the budget I would go for a 4 or even a 6 channel (you can get good used ones on evilbay) for 45 bucks LINK
                        I fly with a MX12 from Graupner and that's a 6 channel one and have it for 7, 8 years and never had any regret.
                        Hope it helps
                        Cheers Richi
                          Gregg
                          Thanks Gregg
                            Hope it helps
                            Cheers Richi
                              U
                              Hope it helps
                              Cheers Richi
                              Useful info Richi, thanks
