Help with lancaster
    Help with lancaster
    Hi all I've just painted the black undersides and sides on my lanc, how do I do panel lines and weather black, when my panel line paint is black. (sorry not a plane man, in fact I know nothing about planes).
  • dave
    • Nov 2012
    • 1828
    • Brussels
    Black is always difficult. I would normally paint in a very dark grey, like Vallejo nato black and then do panel lines in a black oil paint.
    Which I hate to say after you have painted it.
      Yes very difficult on black.
      For me I would try shading and for get the panel lines. Pictures of Lancasters always look patchy on the black.
      Some of the panel lines look a grey.
      [ATTACH]102756.IPB[/ATTACH]
        Thanks for the info guys
        • stona
          • Jul 2008
          • 9889
          Agree. Grey, not black to start with, particularly at 1/72, followed by a lighter grey wash and post shading.
          [ATTACH]102778.IPB[/ATTACH]
            i remember reading somewhere ages ago that you should never paint a model with full black paint as you will never see it in real life only varied shades of grey. have never used it since but only for mixing or preshading and such like
              Perhaps I should remask and spray dk grey, it's actually 1/48.
                Best idea I think Ken. With it toned down you will also see more detail. When you look at black it is just a dark mass with detail killed. Think I would try practice on inkjet very smooth paper to the size of the fuselage cut it out roughly and offer it up to the model. Gives an idea of the contrast of the u/s to the top side.
                For me I would leave the panel lines as they are. With a lighter grey, deeply thinned, I would try wisps from some of the panel line in the tail direction. And perhaps some on mid panels. For me that accentuates and gives a more authentic look rather than filling in all the panel lines. I tried this on my Merlin Helicopter and Walrus. Not easy, as I found, as you need much practice with an airbrush and even then I had problems. But there you go as every one says practice practice and even more practice. But every practice a winner.
                  • 18271
                  As you are willing to re-paint I will back up the dark grey. The only aircraft that were true black would have been some of the very early night fighters/bombers. The "paint" used on those was a form of lamp black. Soot mixed with a binder, it was totally mat and rubbed off all the time. Not very practical. Night was a mix the actually contained a lot of blue so that to was not black either...
                  I am sure that stona can come with all the official info about these.
                  Back to the model.. Dark grey, panel lines at clean places in darker grey or black, places where dirt would collect lighter.
                  Ian m
                    Thanks I will remask and spray dk grey.
                      Matter of interest on weathering panel lines shading etc.
                      I study artists impressions of aircraft. David Hockney and others it gives a good impression of an aircraft without all the minute detail but with just enough detail to represent what that aircraft looks like in reality. Cannot think of any where an artist has represented all the panel lines.
                        I would use either Nato black or anthracite which actually looks black until you put it next to black.
                        scott
                        • stona
                          • Jul 2008
                          • 9889
                          Night was a mix the actually contained a lot of blue so that to was not black either....
                          Ian m
                          It did contain a blue pigment amongst others. If 100 people looked at a chip,99 would probably say it was black. Once applied on an aeroplane it clearly weathered to give a less than uniform black appearance.
                          On scale models black just looks, well, too black. Some modification is needed and everyone has their own favourite way. On small scales, like the 1/72 Lancaster I posted above, I like to just add some white. I don't measure exact ratios, but there is a surprising amount of white in that mix, I'd guess maybe 20%.
                          On larger scales I usually add some red, as here:
                          [ATTACH]102789.IPB[/ATTACH]
                          I know others use NATO black, which is really a very dark green. Methods vary, but the consensus is that pure black doesn't work well on small objects like scale models.
                            Yes I use a green black for a camouflage which has the green/brown top camouflage. These are all warm colours and will be softer in impact than a blue grey.
                            One thing is that the green black should be modified between 1/72 1/48 and 1/32 scales. On the Wellington 1/48 I put a lot of white in testing all the time until satisfied (sort of).
                            [ATTACH]102794.IPB[/ATTACH]
                              you could use the black as a sort of pre shade,spraying light coats of dark grey around panel lines and allowing for shade,multiple coats in the centres of panels, rather than respraying the whole thing dark grey and then highlighting panel lines and such like
