B29 Old Battler
    B29 Old Battler
    Hi People, as you may know or dont as the case maybe, im building a B29, Iv got to the stage where I have installed the undercarriage went in no problem after a night of letting it set, I placed it on its wheels for the first time today, trouble is its tail heavy and the front wheel is of the ground and the tail area is resting on the skid. Anyone else built a Academy B29 is this the norm, or is it a case of trying to add a bit of weight to the front to bring the nose down. ????[ATTACH]104392.IPB[/ATTACH]
  • monica
    • Oct 2013
    • 15169
    do like the looks of this so far,nice clean work,
    • flyjoe180
      • Jan 2012
      • 12400
      • Joe
      • Earth
      Not built any B-29, but a quick look online shows the 1/72 kit needs about 100 grams of weight in the nose area, the 1/48 kit even more.
      • takeslousyphotos
        • Apr 2013
        • 3900
        Here's a daft idea Colin ............. I don't know how much room you have between the cockpit deck and the top of the wheel well ...........But if you have and space a hole drilled in the well and squirt some two pack araldite in there ......... It's quite dense so you wont need much to get 100 grams ......... I have some syringes (we use them at work for oiling components. If you want a few to experiment with (I'm not sure how you'd get the Araldite in the syringe . but if you want some I can post some off to you.
        Peter
        • ojays
          • Oct 2011
          • 1713
          Makes a change to see a B29 in camo, usually only see bare metal!
          Looking good.
          Gregg
            Hi People, as you may know or dont as the case maybe, im building a B29, Iv got to the stage where I have installed the undercarriage went in no problem after a night of letting it set, I placed it on its wheels for the first time today, trouble is its tail heavy and the front wheel is of the ground and the tail area is resting on the skid. Anyone else built a Academy B29 is this the norm, or is it a case of trying to add a bit of weight to the front to bring the nose down. ????[ATTACH]114625[/ATTACH]
            Thanks monica
              100 grams thanks joe, Peter thanks for the offer, but iv got some chem fix which is like Araldite that comes in a syringe ill give it a go, keep you posted Colin
              • takeslousyphotos
                • Apr 2013
                • 3900
                Good stuff Colin .... Hope it works.
                • ojays
                  • Oct 2011
                  • 1713
                  A small suggestion.
                  Try it on a bit of sprue first, to be sure there is no adverse reaction with the plastic!
                  Be a shame to pump some in, to find it desolves all your efforts.
                  Gregg
                  • Dave W
                    • Jan 2011
                    • 4713
                    100g is quite heavy (3.5 ounces to us older chaps!).I would drill your hole,put lead shot in,followed by glue to hold it in place.Alternatively you could make a tail prop from a piece of clear sprue.
                      Have a look at this liquid lead. http://www.rcmodelcentre.co.uk/Liquid-Gravity-Metal-Shot-Ballast/prod_8172.html
                      Consider mounting it on a runway Dio, and glue the nose wheel down.
                      I would be very weary of pouring lots of glue into the nose, when it dries, it shrinks and will distort the local area.
